Hey Guys
Does any have a double cannon full/catback exhaust system for their skyline?
What I mean is something that looks like this:
eBay double cannon muffler
If any of yous do, could ya tell me where you got it from?
Whether it's custom made and any contact details that you have.
Thanks in advance
Peace out. G
I've got a HKS Double canon exhaust, I've only ever seen one other apart from mine.
It looks alot better then that ebay one thats for sure :D
Unfortunately they don't make them anymore, which is a shame. :)
It'd be easy to get one custom made, just get 2 canons that look good and that will fit, and go to a reputable exhaust shop and they can weld a bracket on and do the pipe work, might wanna get it quoted though,
is it just me or does that ebay tip look like it wouldnt be that great for power? cuz at the y intersection the pipe that would lead from the back of the cat to the tip would need to be double the size as each of the tips, not the same so that when it splits in half for each cannon it as efficient as one big tip? instead of it being the same size as only one of the tips?
just guessing?
just guessing?
That one is deisgned for a 2" exhaust (Hence 2" inlet)
It's sad though that some people believe the tip on the last muffler HAS to be like 5 times larger then the inlet... :D
My 3" outlet, on a black 7" round bodied muffler looks stealth as cause you can barely see it!
ive got a dual N1 exhaust an the pipes go alot futhur back to join up to the muffler than that. that ebay one is a pretty bad design i say. just for looks.
Another vic forum member i met had a dual setup, looked very shmick. might have been custom
yeah I know that eBay muffler looks quite bad, though it's the only photo I found at the time that was relevant.
so what are you guys' experiences b4 and after installing the dual pipe or dual cannon exhaust system?
any major performance improvement?
It wouldn't really do the much for performance, but you do get a unique sound and look.
Personally I'm not a big fan of single canons on skylines that have a tip smaller than 4", lol :(
I'll post pics in an hour or so
It's sad though that some people believe the tip on the last muffler HAS to be like 5 times larger then the inlet... :(
no you miss understand what I was saying/questioning.... say your system in 3-3.5 inch... turbo back to the end of the car ( except for the tip) THEN you weld on a pissy little 2inch tip coming out to two larger 3 inch cannons... would that tiny 2inch part not cause a bottle neck? I understand you dont need an elephants d*ck size tip to get the best flow...
btw... in year 12 that was what my 60 year old chemistry teacher said when he came out to have a puff with some of the students and saw my exhaust for the first time.... funny man...
I only went from stock so i cant compare to a single one. I wouldnt think theres a substancial benefit in dual vs single. I got it cause i saw something similar on a 33gtr some 9yrs back and thought it looked sweet. I probably would have ended up with a single canon if I hadnt have seen it..ha
well... lols...
5 and 1/2 inch tip....
Thats a momo course exhaust for ya!
Just Jap do this one for S13/S14
I wonder if a few people put in orders for something this style for R33 they could get them made up and added to their product list, there has been quite a bit of interest for this type of thing on the forums lately...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
