Hey guys, I'm thinking of putting an RB25DET into my 180sx. I found one through my work, it's a series 2 engine with 65,00kms. Now to cut straight to the question. My power goal will be 280rwkw basically just want to know what parts would be neeed. Im aware i'll need certain parts, but what i mean is what size injectors, to work with what turbo, cams, ecu ect. Basically a dream list of parts that i can lash out and buy. Now i dont think i'll want to push beyond 280rwkw, so id want the most responsive turbo that can hit that goal, with aid of cams+gears. I have read the RB25 upgrade thread but its hard to get a good idea cause most people buy parts that are cheap and whatever is for sale at the time. if that makes sence, smart tech guru's need only reply please! thankyou for your help.
Tara-
https://www.sau.com.au/forums/topic/242499-aiming-for-280-rwkw/
fuel pump haha
are you planning on dropping in the RB ecu with it?
also... is there any special reason for the RB25? wouldnt SR20 swap be easier to undertake and engineer?
im assuming that if you can find an RB through work, you can find a good SR...
if you read my post you would see that i already read the RB25 turbo upgrade thread, how do i know what the person is aiming for even if there dyno graph is 280kw? i asked a simple question. I dont want another SR20. I was asking about the RB25DET. And i work at a mechanical workshop so getting blue plates and what not will not be an issue. Should have just asked on ns.com, just thought the crew here may know a little more about RB25's.. Obviously not.
Also, why would i (drop) the std ecu in with the RB25 if im asking about aftermarket parts? So no, i will not be using the std ecu, most likely get a powerFC.
Edited by MissTara
ok byebye then.
OBVIOUSLY its too hard to read up on what other people have done or reccomend
i don't know how you managed to give such a strait out answer, must have been hard! ha! anyway, thanks.
Im going for similar power except im going for 300-350rwkw, only real difference for you is smaller turbo and injectors.
You could also go a walbro 255 fuel pump, its cheaper but i have heard mixed stories about them so im sticking with the ol faithfull 040.
280 rwkw is a tricky figure. Is there a reason why you have selected 280 rwkw as opposed to 250rwkw or 300 rwkw?
The reason I ask is while it is definitely possible to make more than 250 rwkw on a stock motor (I've done it as have numerous other forum members), I would not want to do it for an extended period of time on a stock motor for reliability purposes.
280rwkw is tricky because it is more than I'd be comfortable running on the stock motor and probably not quite enough to justify building a motor. E.g. if I was going to build a motor, I'd whack a slightly bigger turbo on and aim for 300+.
If you tune the car to run on E85 (high octane), you should be able to get 280 rwkw using a highflow rb25 turbo with the larger OP6 rear housing from the VG30 turbo.
A car that I helped build managed more than 280 rwkw with the highflow I mentioned using tolulene added to standard 98 BP ultimate. E85 should be able to produce even more power.
Edited by MANWHORE
cams for 280? there are many people getting 300 with stock cams, maybe add adjustable cam gears though.
Clutch will be needed, tyres are optional after all she did say she was going to drift it :P and of course suspension will be part of the drift set up, not a part required to get 280rwkw which is purely the question i answered thats why i left out clutch (and i didnt think of it at the time).
hks gtr-s
3 1/2 zaust high flow cats
550cc injectors
044 fuel pump
exedy brass/cusion button clutch
front mount (with nice silicon joins and heavy duty clamps)
ebc (greddy profec b spec II)
microtech ECU :) (people will dispute this, but no BOV and your dosing)
maybe chuck an oil coiler around there some where
suspension (tein or HSD coilovers)
diff
and that 180sx will skate like its on ice :) :)
280rwkw is easily achievable on an SR20, why on earth would you want to put an RB25 in there other than to make your car nose heavy and for bragging rights? Retaining an alloy SR20 block as opposed to a cast iron RB25 block is worth the extra power you'll have to make to compensate for the added weight.
Seriously, save the time and money you'd waste on shoehorning an RB25DET in and make a bulletproof SR20DET.
im no race car expert but im guessing with the extra weight over the nose it would also make it understeer which is definitely not some thing you want in a drift car.
Edited by W0rp3D
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
