Hey guys, I'm thinking of putting an RB25DET into my 180sx. I found one through my work, it's a series 2 engine with 65,00kms. Now to cut straight to the question. My power goal will be 280rwkw basically just want to know what parts would be neeed. Im aware i'll need certain parts, but what i mean is what size injectors, to work with what turbo, cams, ecu ect. Basically a dream list of parts that i can lash out and buy. Now i dont think i'll want to push beyond 280rwkw, so id want the most responsive turbo that can hit that goal, with aid of cams+gears. I have read the RB25 upgrade thread but its hard to get a good idea cause most people buy parts that are cheap and whatever is for sale at the time. if that makes sence, smart tech guru's need only reply please! thankyou for your help.
Tara-
https://www.sau.com.au/forums/topic/242499-aiming-for-280-rwkw/
fuel pump haha
are you planning on dropping in the RB ecu with it?
also... is there any special reason for the RB25? wouldnt SR20 swap be easier to undertake and engineer?
im assuming that if you can find an RB through work, you can find a good SR...
if you read my post you would see that i already read the RB25 turbo upgrade thread, how do i know what the person is aiming for even if there dyno graph is 280kw? i asked a simple question. I dont want another SR20. I was asking about the RB25DET. And i work at a mechanical workshop so getting blue plates and what not will not be an issue. Should have just asked on ns.com, just thought the crew here may know a little more about RB25's.. Obviously not.
Also, why would i (drop) the std ecu in with the RB25 if im asking about aftermarket parts? So no, i will not be using the std ecu, most likely get a powerFC.
Edited by MissTara
ok byebye then.
OBVIOUSLY its too hard to read up on what other people have done or reccomend
i don't know how you managed to give such a strait out answer, must have been hard! ha! anyway, thanks.
Im going for similar power except im going for 300-350rwkw, only real difference for you is smaller turbo and injectors.
You could also go a walbro 255 fuel pump, its cheaper but i have heard mixed stories about them so im sticking with the ol faithfull 040.
280 rwkw is a tricky figure. Is there a reason why you have selected 280 rwkw as opposed to 250rwkw or 300 rwkw?
The reason I ask is while it is definitely possible to make more than 250 rwkw on a stock motor (I've done it as have numerous other forum members), I would not want to do it for an extended period of time on a stock motor for reliability purposes.
280rwkw is tricky because it is more than I'd be comfortable running on the stock motor and probably not quite enough to justify building a motor. E.g. if I was going to build a motor, I'd whack a slightly bigger turbo on and aim for 300+.
If you tune the car to run on E85 (high octane), you should be able to get 280 rwkw using a highflow rb25 turbo with the larger OP6 rear housing from the VG30 turbo.
A car that I helped build managed more than 280 rwkw with the highflow I mentioned using tolulene added to standard 98 BP ultimate. E85 should be able to produce even more power.
Edited by MANWHORE
cams for 280? there are many people getting 300 with stock cams, maybe add adjustable cam gears though.
Clutch will be needed, tyres are optional after all she did say she was going to drift it :P and of course suspension will be part of the drift set up, not a part required to get 280rwkw which is purely the question i answered thats why i left out clutch (and i didnt think of it at the time).
hks gtr-s
3 1/2 zaust high flow cats
550cc injectors
044 fuel pump
exedy brass/cusion button clutch
front mount (with nice silicon joins and heavy duty clamps)
ebc (greddy profec b spec II)
microtech ECU :) (people will dispute this, but no BOV and your dosing)
maybe chuck an oil coiler around there some where
suspension (tein or HSD coilovers)
diff
and that 180sx will skate like its on ice :) :)
280rwkw is easily achievable on an SR20, why on earth would you want to put an RB25 in there other than to make your car nose heavy and for bragging rights? Retaining an alloy SR20 block as opposed to a cast iron RB25 block is worth the extra power you'll have to make to compensate for the added weight.
Seriously, save the time and money you'd waste on shoehorning an RB25DET in and make a bulletproof SR20DET.
im no race car expert but im guessing with the extra weight over the nose it would also make it understeer which is definitely not some thing you want in a drift car.
Edited by W0rp3D
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
