  • Replies 64
Whats a safe boost limit to run on an R34 GT-R V-Spec II? I only have Blitz Nur cat back exhaust & the rest is completely stock. It seems that most people say that 1.2 BAR is too much even for R34 GT-R's stock ceramic turbos? Is this true? Has anyone actually shattered their stock R34 GT-R turbos from 1.2 BAR boost?
I am contemplating getting the Greddy Profec B-Spec II and bumping boost up to a max 1.2 BAR... but then again maybe not?
Thanks in advance for any info/help!
it'll work, but it will eventually go bang.
The general rule of thumb for ceramic wheeled turbos is no more than 1 bar.
I ran 17-18psi through a toyota ct20b turbo (ceramic) and it lasted a bit over a year before it spat out the "fins" on the wheel :P
doesnt the R34 run steel wheels from the factory?
if they arent ceramic, and they will hold together at this pressure, ur still talking about wringing dam near 18psi out of tiny stock turbs, not sure how efficient they are at this boost...could be fine...but worth finding out
also just adding more boost without a retune wont yield the best results, look for some aftermarket management, even a piggyback ecu is a good option if you only want mild mods
uve spent money on a nice car, dont risk doing damage by increasing power/boost without making the appropriate support mods
Okay I see. So aftermarket turbos will be a necessity!!! But having said that, then the support systems will have to match... so what about the following then:
HKS GT-SS Turbos
NISMO 600cc Injectors
NISMO fuel pump
Apexi Power FC & Hand Controller
Trust Oil Cooler
Then Trust Profec B Spec II boost controller running @ 1.2 BAR.
Should produce some decent power/reliability then eh??? Or am I missing somthing here? :P
R34 GT-R's still run ceramic wheels. Its only the R34 N1 that have steel ones so unfortunately i dun have them. :P
u dont need dumps, just get front pipe and a boost controller. I run 1.2 bar for daily driving, no dramas at all as you are not on boost all the time.
If I do a cruise, putty road for example where it will be on and off boost constantly I just knock it back to 1 bar.
Ive got mine set to 1bar as those internal gates arent very good at controlling boost in the first couple of gears which can spike boost to 1.20
test your boost in 3rd on the freeway all the way till bout 7000rpm and check the highest reading; it should be 1.01 or 1.04 etc
you want some leeway to keep the spike down; if you set yours to 1.20bar im sure it'll go higher when you take off hard in 1st and full throttle 2nd.
Then they will blow!
add dumps and front pipe and you've got a winner :ermm:
Have you seen R34 GTR Dumps?
They dont need changing at all, they are easily good for over 350rwkw.
See Snowman's graph, thats with stock dumps and better than most people on here for the power.
Stock airbox
Stock dumps
Dont need a EBC really
  • 2 months later...
I'd like to see where people are getting their information on R34GTR's having ceramic turbine wheels. I have information to the contrary by a reputable Garrett company and tomorrow I will have proof when I check the one I have here. Stay tuned.
Maybe the people that have killed them?
GTRGeoff purchased Snowmans old turbos (ceramic), they spat a rear wheel just like any other GTR turbo does... i think cost him a motor possibly too, again, just like ant other GTR turbo can do
Ive turned my boost down a tad, ramps to 1.05 or so in the first 2 gears, 3rd gear full load is 1.00kg/cm on da dot.
umm something in r34 gtr turbos are ceramic, nissan did it to increase torque over the r32/33; mine are holding up nicely still but i will be changing to some new garrett or hks items simply for reliability.
so R34 GTR has better dump pipes than R32 and R33 GTR ??
my car is stock at the moment apart from Fujitsubo Legalis exhaust , K&N panel filter and 100mm thick intercooler
during the day boost peaks at 1.1bar and at night 1.25bar
and i dont have a boost controller .... :happy:
what should i do ??
Edited by TuLaLiT
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
