  • Replies 486
Posted Images
dont forget my PC luke
you mean my pc? XD
not sure what i want to do with it yet, one of my friends said they wanted it a while ago =\ and it's also on offer to ben and nene if their computer dies on them coz they have helped me out a bit... so i think i'll be hanging on to it for a little longer, soz
what there's Nothing wrong with Nene's computer might need another gb of ram but thats it
it was crashing all the time =\ mebe they bought a new one... but the old one seemed pritty broken from what nene was saying
thats all cool mate
the only reason i was after it is my CPU cooked itself
overclocked the motherf**ker
3.2GHz overclocked to 3.6GHz
it ran fine for just over 1.5 years
thats all cool mate
what sort of cpu/socket? I have a couple cpus lying around
-D
3.2 intel would either be the (640) or possibly older my guess is 775pin 640
Luke its a 1yr old HP Pentium D 2.8 ghz i think and i think it has like 512mb of ram but it may have 1 1gb stick really cant remember possibly just needs a format
3.2-3.6 isnt much of a OC i had the P4 650 stock is 3.4 running on 4.02ghz on air
But also dont forget over clocking a little bit 3.2 to 3.6 and have a shitload of services run on your pc at the same time is not a good mix
plus it has lasted well just over 1.5 years so thats a good deal i reackon
and that computer was rarely shutdown as it was acting as my server
it was also my test DEV pc for random things like studying for exams or just trying to get something to work
Well luke if you still wanna do this then the offer is there for you my friend
If you can double check which socket it is, I'm sure I can find you a replacement. I have at least 2 intel chips and 2 AMD 64 chips so I just gotta pull them out n see what they are...
-D
Good news guys! Got the call that the calendars are ready to be picked up thursday! Sooo next step is getting them to you guys.
Im happy to meet people on friday at vilis, just not sure what time yet, otherwise can work something else out.
At this stage theres still 5 left for sale.. I thought they would be snapped up alot quicker than this, but all good.
Those that put their car in but havent paid yet, let me know what you want to do, as to order more i have to do lots of 5, paid upfront.
*edit*
Im paying the difference for this first lot that is going to be collected so I can get them out asap to you and cos im so excited bout them, but the next lots of 5 I will need paid in full, so 5 payments.. before I will collect them
Edited by *flick*
awesome Ben :ermm:
I had u listed in my book as reserved lol so your safe there :(
And Preiss aswell has 1 reserved.. so thats 22 sold, 3 left!
Im happy to sacrifice the one i was gonna take, and buy up in the next lot. To get the 5 extras printed, would only take a few days the printer said aswell, so if you miss out on first round dont stress, its easy to get more!
Edited by *flick*
I get paid tomorrow, put me down for 2 flickster.
-D
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
