I have been searching for things to throw into my r33 gtst series 2 and every web based search i make there is a larger throttle body i can put onto my car,,,, ebay is full of them and here is a link so you guys know what i'm talking about...
http://sydney.gumtree.com.au/c-Cars-for-Sa...QQAdIdZ83573567
my questions are...... are these worth the money???
.... is there any real gain over the stock one????
... has anybody had good results after buying one of these "universal" type throttle bodies???
... how easy are they to install???
or is it something worth waiting untill i get a new plenum and match them up????
cheers
https://www.sau.com.au/forums/topic/242556-80mm-throttle-body/
man unless ur gona change ur unlet manifold i rekon personally that a bigger throttle body does nothin, maybe a louder induction noise. Its liek puttin water in a funnel u but the bottom bit is the same size, all it will do is hold more capicty but flow the same if that makes sence.
wait until you upgrade your plenum,
then buy a throttle body that is the apporpirate/reccomended size.
the plenum will probably come with a throttle body, alot of manufactures sell them as a kit with all the required ancillaries.
i think if you have done little to no mods on your car it would be a wast of money and time,plus you engine response will be down , if you running say 400 + hp then give it a go with a 90mm q45
Edited by WARLORD
yep plazmamans comes as a kit (for the neo head anyway, thats all ive been looking at) about $1.3k, for plenum and t/b, uses standard cables and sensors etc. (their website is pretty good, fair bit of info on their)
always prefer buying aussie made when its appropriate
You won't need to upgrade until you do your plenum... then i would use a Q45 TB, i got one of the ebay/universal TB's and it stuck open at rev's so u needed to give the throttle a stab to release it (not a good thing in a 450hp car). Also it wouldn't shut enough on 0% throttle so it would idle on about 1300rpm, and u need to get a flange welded on so when it gives u the Sh)ts u have to cut it off and try not to destroy ur plenum... then u'll just go spend $160 on a Q45 TB anyway.... so they are a waste of money,
Just my 2c on the matter lol....
waste of time and money, if you can show me that your stock throttlebody is causing a significant pressure drop at mild to medium power levels i will buy it for you, how's that?
you will end up with a touchy throttle at initial opening and doughy as it gets towards wot.
Edited by RB30-POWER
  • 3 months later...
big bump also been reading up but no1 can tell for certain where the stock throttle body starts to become restriction. some people say 250 others go 350 others go theres no restriction.
anyone know how hard it is to get a q45 on a plazmaman manifold?
aiming for 320+ so im guessing might aswell be safe and upgrade.
Stock manifold & throttlebody on my 30 (they are off an R32 RB25DE), made 365rwkw in the previous car they were in - we think that they were a restriction at that point. Same turbos are on a new 30 (but with a 25DET head) with a GReddy intake manifold and q45 t/b, made 395awkw @ 2psi less boost. (Original car was a rwd, new car is 4wd).
I would say that is about the level the stock manifold and throttlebody are good for :(
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
