  • Replies 102
Posted Images
What's the install like on these? Do you need to solder or anything or is it all plug in? I'm pretty interested but only if I am confident in installing them myself.
What Phil said :)
kk
Well I was thinking of just going with 4300k but you mentioned somewhere 5000k?
Have you got any pics of 4300 or 5000 on a car? 6000k seems a bit bright for night driving on the streets.
Do the HID's work for both low and high beams or just low beams? Are my high beams still useable if I get the HID kit?
Sorry for the questions man! Maybe shoot off a PM to me if its easier.
Kelvin rating has nothing to do with brightness.
All kits are 3x times brighter than stock halogens.
Kelvin rating is the colour of light it produces.
For example:
post-32255-1228864757.jpgpost-32255-1228864776.jpgpost-32255-1228864909.jpgpost-32255-1228864928.jpg
Kits are low beam only and yes you will have normal highbeams.
I can also get a higher quality Digital HID kit from Bosch and Siemens.
They come with higher quality bulbs and new digital ballasts.
These digital HID kits are latest technology.
These kits are $225 delivered.
For those who dont ming paying extra for quality then these kits are for you. :D
Interested in one of these kits (6000k), what kit would i need for my 32 GTR?
Thanks,
Dan
Thanks,
Dan
Im not sure Dan, you will have to find out what bulb suits your car and let me know.
Once you do PM me and we will go from there.
Dani Boi your kit has been ordered :)
Thanks mate :P
Thanks,
Dan
R32 bulbs would be the same for R32GTR I would think, if that's the case they are H3's, but double check that first!!
Thanks mate :P
Actually there are a few types for 32s,all depends if you have reflector or projector headlight assemblies.
So yes please check to see what bulb types suits your car before ordering.
:P
Thanks for that guys- I havn't been able to check headlights yet as I work away a month at a time and the guy working on my car hasn't got around to checking globes yet!
Ive attached a photo so if possible could you please confirm projector headlights?
Thanks,
Dan
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
