Hey, i was hoping someone new what the stock boost for the r34 GTT is once youve removed your boost controller. I'm putting it back in but it wont be for a few weeks so i was just wondering what kind of boost id be running until i put it back in.
https://www.sau.com.au/forums/topic/242841-r34-gtt-stock-boost/
OK.. from my understanding the ER34 holds boost up to 5 psi until 3,500rpm (this is due to the inlet and exhaust Camshafts) the camshafts are somewhat "Variable Valve" and NO.... not like a HONDA
After 3,500 rpm the car should hold boost to approx. 7-9 psi all the way to redline
The car will creep more towards 9 psi if you have a Frount Mount Intercooler
It's not directly related to timing changes... it's the dual stage solenoid. if you ground it, it'll run 7psi constantly.
agree with howie on this 1.
r34 runs dual stage solenoid with 5psi to 4500rpm then goes up to 7psi til redline.
ground the solenoid and u get 7psi til redline or change the actuator to a r32 actuator and get 10psi to red line if the solenoid is grounded or a 7psi-10psi dual stage.
Once youve removed your boost controller youll blow your turbo :P ...
Lol why will i blow my turbo, i just need to take off the boost controller for like a week until I've got it passed at the cop shop. I dont see why removing the boost controller will blow my turbo, according to what everyones said on the forum itl be running around 5 to 7 psi which is 4 psi less than what ive got it running on now (which btw its dyno tuned at so its not unsafe for my turbos)
  • 15 years later...
18 minutes ago, silviaz said:
Is overboosting normal even with a boost controller?
Well....no. But yes. But no.
First up, let's ask what you yourself specifically mean by "overboosting"? Because there is "overboosting" and there is "overboosting".
If the boost pressure exceeds the maximum value that you want to run, then technically that's overboosting. But even the very best boost controller will still exceed that maximum, even if only by a little bit. And fancy PID control actually even fully expects an overshoot of the target while attempting to achieve it. The images on the left, particularly the bottom one, show what PID control typically looks like with some overshoot.
But, if you are not talking about a proper electronic boost controller, and instead are talking about some simple boost tee style thing (which is really just a spring based pressure relief/regulator type thing) then....they can be either pretty good or pretty bad. The pretty bad ones can have terrible control and allow either quite large overshoot on the way to achieving target, or they might even allow the boost to creep way up over target towards the end of a pull, well, after the initial achievement of target.
Even a fancy electronic boost controller might not be able to prevent overboost, by which I mean the longer term creep way above the target, if the exhaust and/or boost control mechanisms (the actuator and the wastegate) are not capable to actually giving you the control.
In your case.... You're pretty stock right? There's no situation where you should find yourself with problematic overboost. Even a shitty boost controller shouldn't cause you troubles. it might "overboost", but that shouldn't be a major issue. Except of course, if you're running without a tuned/tuneable ECU. In which case.... you've probably already been told to stop f**king with it until you do have.
Nope mine is quite modified, I went from 12 max psi to almost 15 I don't want to blow my stock turbo. I had my car tuned btw I forgot to mention.
Edited by silviaz
Anything with a stock turbo is not "quite modified". It is basically stock. You're describing essentially what my car is. Doesn't matter what exhaust, intercooler, injectors, AFM, coils, etc etc you have. The stock turbo is good for about 200 rwkW at best, and that is not "quite modified".
And.....your stock turbo can and probably will blow up even at 12 psi. I ran mine at 12 psi for....probably 10 years, maybe more. Then one day it exploded the turbine. There are many other examples of the same, and many examples of them dying even without ever having been turned up. Some died when nearly new. Others died only after protracted abuse.
I even ran my RB20 stocker at 17 psi for a while (without realising that that was why it was so fast) because of a little problem with my boost controller. It was fine (and luckily, apart from the risk of the turbine exploding, the engine could take it because I had fuelling and tuning to suit). But it might have died on the first occasion.
Your turbo is now 25 years old. It is on borrowed time regardless of what you want. It will die at some point. Just be prepared to put a new turbo on it. I'd been waiting for a decade for mine to go when it finally did.
Do not run your turbo at 15 psi though. It can probably take it spinning up there briefly, if that's only a brief thing until the controller gets control. But extended operation at that speed will kill it.
But remember what I said above - it is a lottery.
And also, there is no way that a boost controller should be allowing the stock turbo to run well over your boost target. Not a good boost controller anyway. I have a million year old Profec and it will hold 9, or 10, or 12, or 14, or whatever I ask it to.
  • Like 1
Yeah, I'll need to check with the tuner it sounds like. I only wanted 12 psi max. I had the mechanic check the shaft play and they told me it was good. I'm hoping I didn't do damage when I did a quick pull and hit 15 psi.
Did you thrash your car regularly for 10 years or was it just a hit here and there? I'm trying to get an idea of how long I can rock this. Ideally I don't replace the turbo lol. But yeah it's a lottery at the same time like you said.
Edited by silviaz
Shaft play won't tell you much in this case, the ceramic wheel is bonded to the shaft which is where it lets go
  • Like 1
This.
Shaft play is not "broken". Turbine in thousands of crumbs in your cat converter. That's broken.
It will explode suddenly and you will immediately lose all boost and any hope of ever making boost again.
It can happen today, it can happen tomorrow. It might take another 5 years. It can happen at 10 psi, at 12 psi, at 17 psi. Mine blew as it came on boost so it wouldn't have even spooled all the way up and was probably only making 5 psi at the instant it let go.
Yes. I drive it hard regularly. Most miles are done commuting, but it gets the arse hung out on every roundabout, every on ramp and no wanker in a Commodore is allowed to win at the lights.
  • Haha 1
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
