its r33 40th anniversary front bar
I was under the impression that the only body option for the 40th anniversary was the GTR rear wing, does anyone have any more info on this "optional" front bar?
u can buy one here in japan :0.. took me a while. but found one to buy.. well, its closer then anyone can get so far, unless you buy fron nissan :P
http://www.importmonster.com.au/view?url=h...p;title=R33%20F
like i said before > its the closest anyone will get if there after a 40th anniversary front bar!.. i have not seen a fibreglass version in 6 years, and this is the best i can find if ppl need one.. there really isent much difference in the two bars, and it is shorter in hight just like the gtr style 40th anniversary front bar, so not hitting the ground .. take a look.. it really isent that different.
lol @ wrong bar..haha.. im just giving some ppl some options with the annoying series2 front end..
heres a pic so you all can look and compare the 2 bars with pictures :(..hhehe
to me they look the same but with extra air vents on the side being a aero version bodykit. umm which makes sence to me.. people who are talented enough to look at 2 pictures at one time will see they are the same exept one thing different, a extra air vent on the side of the bar.. still lmao at wrong bar..hehe
Edited by seriesII
no its ROFL at wrong bar now, they look noway near the same dude.. the middle part down the bottom is different the vents on the side u mentions is different, the whole front bar is flared out like vertex style theres not lil lip vent at the bottom.
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
