Hi all,
I have a set of KYB model number 341287 front shockers that I am looking to replace my tired worn ones in my Series 2 4WD.
Problem is that when I took them out of the box and measured the length up against the originals, the KYB's were about 20-25mm longer.
Now this promts me to ask whether they are in fact R33 GTST or R33 GTR? the suppliers reassure me that they are for the R33 GTR according to KYB listing. I remember reading somewhere that the R33 GTST's are a bit longer.
I will also be fitting lowered Kings springs (R33 GTR) to work with the KYB shocks but am concerned about the shock travel characteristics with the lowered springs as they are already longer than original (springs 30mm-40mm lower + shocks are 20-25mm longer = 50-65mm less travel in shocks than they designed for). Will they bottom out?
Questions;-
1. Is the 341287 KYB the correct part number to use for the Stagea?
2. Also does anyone know of any alternatives readily available at a reasonable price?
Nissan Aust original are about $400/pair + 2 week wait Japan.
Bilstein's are about $590/pair (B46 2107 FR Bilstein Sport B6 R33GTR)
Thanks, do you know what the correct KYB part number is?
You won't get anything in oz, you will only get japanese domestic model KYB's that are made for Stagea's, or are you after the R33 GTR ones ?
Hi all,
Questions;-
I got my Bilsteins (in NZ) for about half that by getting a set that had been traded in .The Bilstein trained guy reconditioned and valved them to suit my Stagea - you could try phoning around.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
