im in the market for an ecu, either a stand alone one or a piggy back just to make the most of my stage one mods
ive noticed afew of these Mines, LAP etc remaped ecu's popping up, sayin they hav been programed for cars with full exhaust, intercooler, 12psi...and to lean out afrs...some even sayin they were tested and there cars (r33 gtst) made a tad over 200rwkw with this in place
can u trust these? are they worth it, i dont hav a lot of money to spend on an ecu..im only after around 200rwkw and i will never go any further
anyone tried these, any proven results...all comments would be appreciated
:D
https://www.sau.com.au/forums/topic/244366-ebay-chipped-ecus/
risky as the chipped ecu is specific to the car it was initially tuned for, most will give you an idea of base line mods supported when chipped, but at end of day, its still someone else's car mods and if u use it, have to be sure its suitable for your mods.. if u have bought it, maybe a dyno run to confirm safe afr's
Edited by BWRGTR
nah havent bought one...
im just asking coz ive seen afew r32 gtrs running Mines chipped ecus with stage one mods makin sum descent power
dont know how there AFR's are and fuel economy though...
so im guessing an apexi safc would be a wise move?
My car had an IMPUL piggy back ECU. It was making decent power but leaning the engine off it tits due to it being tuned for 102 octane (Jap premium). Not sure if the mine's computers are tuneable but this one certainly wasn't, so it had to go.
I have just sourced myself a brand new APexi Neo - Will be getting that tuned soon.
My car made 175rwkw with just a catback and cheap pod. My tuner reckns he can net me 220rwkw on a rich tune. Ill see. i just want a safe "semi-rich" tune.
ive also got a series 2 r33 gtst, if i can get anything above 200rwkw i'l be happy as larry !
only mods are full 3" turbo back stainless exhaust, 3" high flow cat, pod/cold air intake, cooling pro bar n plate front mount, turbotech boost controller at 10psi and exedy sports tuff clutch..
im willing to run around 12psi....ive made my mind not to get a chipped ecu from ebay, rather spend the money on a safc and get it tuned specificaly for my car/mods
cheers
ps. are all those ecu's with chips locked? no tuner here in aus can retune them?
There's not much difference between having some remap a stock ecu or an already chipped ecu, an eeprom still has to be burnt and soldered directly to the board or dropped into a cradle (most use cradles as the use a romulator to tune then burn a chip when done).
IMO, don't bother with a generic chipped ecu. Buy the safc and have it tuned on a dyno.
a chipped ecu from japland tuned for x x x mods would be ok, but youd still want a safc at the least to make sure fueling is spot on
a haltech interceptor (safc / sitc + more in one) might be a better option on your stock ecu
or talk to Toshi about redoing your ecu chip (I did that !!! so happy, and with safc/sitc can get a top tune)
so many options these days, cheapest is safc only
then ebay ecu + safc
or ebay ecu + haltech interceptor
or Toshi remap (fine if he's there, mine was long distance tune so still need the safc/sitc for minor adjustments)
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
