off the top of my head l think it is
Spark plugs if still using factory
Timing belt
oil + filter
as every thing else l think is done at 80,000 such as
coolant
brake fluid
air filter
fuel filter
also if you havent done your diff oil and gearbox oil done get that done to. l would also do what ever has been missed in previous services to get services back on track.
Hope that helps
Best bet for the 100k service is to check what nissan recommend for a 34 100k in a workshop manual, workshops and people will do more / less its up to you really.
I personally when I get car a change everything so I know its done :)
100k service, I would do the following.
Timing Belt, Idler and tensioner bearing
Aux belt, aircon belt.
Oil Filter
Oil
Fuel Filter
Radiator Flush
Spark Plugs
Gearbox oil
Diff oil
Transfer case oil
Brake pads, if need replacing
Safety check.
I got quoted about $900 for the service? to change the timing belt and spark plugs. Does that sound about right?
Only the timing belt and plugs? Thats a bit too much
For my 32GTR, I bought the service kit from Kudo's Motorsport. Got the timing belt, water pump, idler, tensioner bearing changed, raidator flushed for around $950. The labor was $500 flat. You can change the spark plugs yourself, it ain't that hard dude.
cheers guys!
the guy reckons he has already done 100k service and changed water pump...does that need to be done?
sounds strange to me :P
The water pump dosent need to be done by the books but isnt a bad idea, as it requires the timing belt to be removed to fit a new one. Due to the age of most skylines these days getting your water pump done when the timing belt is done,it could save a bit of money done the road.
My car has about 98,XXX on it i got home the other day noticed water coming out from under the engine, water pump craped it self :D so i did the full service belts fluids new water pump, Idler and tensioner bearing and new spark plugs :P there goes a week wages :D
  • 4 weeks later...
After your 100,000Km service has been done, TAKE NOTE that according to the R34 OWNER'S MANUAL...
THERE IS A MAJOR SERVICE EVERY 40,000Km
This would/should have been done at 40,000Km and at 80,000Km
MANUAL LEGEND SAYS...
R = Replace
I = Inspect
L = Lubricate
Therefore, at 140,000Km and at 180,000Km involving...
Engine Oil = R (and on turbo engines, every 5,000Km or 6 months whichever is sooner)*
Oil Filter = R*
Drive Belts = I
Engine Anti-freeze coolant (Ethylene glycol based) = R
Cooling System = I
Air cleaner (paper type) = R*
Fuel Lines = I
Fuel Filter = R*
Spark Plugs (Platinum) = every 100,000Km
Heated O2 Sensor (Exhaust Gas Sensor) = I
EVAP Vapour Lines = I
Timing Belt = every 100,000Km
Brake, Clutch & Auto Trans Fluid (for level and leaks) = I*
Brake Fluid = R*
Brake Booster Vacuum Hoses, Connections and Check Valve = I
Power Steering Fluid and Lines (for level and leaks) = I
Brake, Clutch & Exhaust Systems = I
Manual Trans Gear Oil (for level and leaks) = I
Diff Gear Oil (for level and leaks) = I*
Limited Slip Diff Gear Oil (for level and leaks) = R*
Transfer Fluid (for level and leaks) = R*
Steering Gear & Linkage, Axle & Susp'n Parts, Propellor Shafts & Drive Shafts = I*
Wheel Alignment & Rotation & Balancing = I
Brake Pads, Rotors & Other Components = I*
Locks, Hinges & Boot Latch = L*
Seat Belts, Buckles, Retractors,Anchors & Adjustors = I
Foot Brake, Parking Brake, & Clutch (for free play, stroke & operation) = I
Ventilation Air Filter = R*
Note:- Anything that has a '*' next to it will need attention more often under harsher operating conditions.
Hope this helps,
Tez
R = Replace
I = Inspect
L = Lubricate
Oil Filter = R*
Drive Belts = I
Cooling System = I
Fuel Lines = I
Fuel Filter = R*
Brake Fluid = R*
Hope this helps,
Tez
EVEN ON MY R33 OR SOMEONE ELSE'S R32, THIS ENGLISH TRANSLATION IS WORTHWHILE DOWNLOADING/COPYING !
  • 4 weeks later...
I've heard in a few different places now people recommending to get the idler and tensioner bearings replaced. What are these 2 bearings used for and do they really need replacing ? how much to replace them on an R34 GTT approx. ?
I've had my 100k (even though odo is still < 70k but who can trust that..) service already with all the belts incl TB changed as well as oils, water pump etc but never had the bearings touched.
Edited by Delta Force
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
