Ok. Well the other day i left my car at the train station (had to be in the city and it was peak hour so i thought i would be better off training it) I parked my car all was well. I got back to my car about 2 -3 hours later all was still fine, or so i thought. I parked my car at home went out blah blah blah when i came back my sister who parks behind be had left a written note saying that "someone looks like they have tried to break into your boot, or into your car via your boot." (i never saw it at the train station or at home because who checks that before they drive?) I was shocked and went out and checked, low and behold some douche had shimmied off the boot lock (there are about three key marks where they have pried it off). Nothing was stolen and they have not been able to get into the car if that is what they where aiming to do (why not just smash my window?) But now i am left with a hole where the lock was how can i fix this? I assume that i cannot just buy a new lock because my key wouldn't fit it? Is there away around this? I was thinking to just get it al filled in and resprayed and thus deleting the lock then just using the boot release to open the boot in the future? Any suggestions or tips would be great.
P.s It is a r32 gtr, if that helps with parts ideas.
Cheers
https://www.sau.com.au/forums/topic/244438-what-to-do/
Unlucky mate, Never had any attempts on my car yet so I've no experience on claims or anything. But this could be a good thing, get the hole covered and remove the badges from the back of your car for a stealth look, you know you've always wanted to :(
https://www.sau.com.au/forums/topic/244438-what-to-do/#findComment-4255524
You should be able to buy a new lock either secondhand or new from Nissan. Take it to a lock smith like "Diamond Lock And Key" in Osborne Park (Main street) and get them to redo it to accept your current key. Saves you from having to have different keys for different locks.
https://www.sau.com.au/forums/topic/244438-what-to-do/#findComment-4255751
Hey champ What F(*ks they must prob going for a sound system which is known to happen alot! their not much you can do besidse try to park it else,
sucks tho cnart do much
(Shave the boot lid so no lock use the lever) ?
https://www.sau.com.au/forums/topic/244438-what-to-do/#findComment-4255882
Maybe you can get a new key barrel and take it to the locksmiths and they will cut the barrel to your key.
Not sure how much the barrel will cost itself, but it beats getting a secondhand one which means you will have to carry an extra key.
By the way, my one is deleted.
https://www.sau.com.au/forums/topic/244438-what-to-do/#findComment-4256662
thanks for the Suggestion Brad. So any gtr32 key barrel will do? Or can i use like a r33 one or any other models one? and then they will just configure it to take my key? Any idea how much that will cost? it will be that or deleting the lock i guess depends on how easy either one is hrmmm. Suck like why couldnt they have just left the key barrel after they f**ked with it it would have been no use to them :).
https://www.sau.com.au/forums/topic/244438-what-to-do/#findComment-4256789
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
