  • Replies 47
I'd say that depends on who you talk to....
I believe mine runs heaps better with the pod, even before boost increase.
I'm no mechanic so someone will contradict me for sure, lol.
I think on stock it is noticable but depending on mods some say it is less needed, just a good flowing panel filter in the box is best.
if you have FMIC and can make a CAI and a box to cover the pod, may be best option.
also depends on how much flow the particular filter has.
As i said i read through threads in forced induction, they simply compare filters.
My question is different if you take another look...
I just want to know what would be better for a stock R33 GTS-T. A Pod Filter or a Pannel Filter
Your lucky R31Nismoid has not closed your thread, as there have been a few threads about this and Ash is a true believer in the stock air box FTW.
Your gonna get mixed answers here, cuz its personal preferance and experiance.
I have to HKS pods as it came with the car and they are doing fine.
I would say stock air box or upgraded high flow panel filters are good for about 300 to 400 kWs.
Pods are very good for high end tuned performance cars. As for stock, it does not make much of a difference, pod or panel filter.
Ask Johnny, he did a test on his R34 GTR with an APexi panel filter then twin APexi pod filters and he had quite a gain in kW's.
I now have a pod on my GTST and as for performance i did notice the responsivness was better but not enough difference to notice anything significant, not running any serious mods so may be a lot different for people that are. One thing I did notice for sure is the induction noise, bit louder with the pod on but that could depend on the brand you get as well?
Did you have a decent hi-flow panel filter in there before?
My guess is stock nissan or similar, so of course your going to notice a minor difference going from crap to a decent flowing filter setup.
If stock airboxes can make 400rwkw on BIG GTR's (with the side airbox restrictor thingo removed for the flow in R34's)
Good enough for run of the mill setups below that, plenty of threads on it, Dezz even posted some dyno results which showed such little difference it wasnt worth going pods due to factoring in increased intake temps
ok here is the thread.
This is about airbox with lid on/off
http://www.skylinesaustralia.com/forums/Ai...html&hl=pod
And read the whole thread, interesting points come up over the course of it, and ideas etc
... just get a high flow panel filter like r31nismoid said.
I have a Trust Airinx-GT panel filter in my Stag, is that considered rubbish or should i get a better one? Like Pipercross or something else? Any recommendations? < $100. Or are they all much of a muchness.
Edited by webng
There is no distinct answer, there are so many factors that can influence the results. Mainly if you standard airbox/filter set-up isn't a restriction than you'll see little to no power/response change.
However lets not kid ourselves must people swap to a pod set-up for the induction noise, any upgrade in performance comes as a bonus. :P
id go Jap stuff, but thats just me. Pipercross doesnt have panel filters for Skylines
just clean your current one
i am still running my airbox with a k&n (fmic, pfc, avcr, exhaust) and at my last dyno session it was causing a restriction. it seems the issue is with the mouth of the airbox. so if you don't plan on modifying your car, the stock airbox is ok after that though you might need a pod or modify your airbox.
Well from reading it looks like the best option for a stock car is just a hi flow panel filter.
Summer coming up and all will mean higher intake temps unless you get a partition which will set you back another $100 and from what people have said it will make very very little difference if any.
So hi-flow pannel filter
-Cheaper
-Defect free
-Lower intake temps on hot days
Pod Filter
-Intake noise
-Better for highly modified cars
This brings me to my next question on Hi-Flow Pannel Filters..
What kinds are there?
What is the best one(s)?
Thanks guys!
I personally wouldn't recommend using a oiled filter with a hot wire air mass meter set-up. The filament is extremely sensitive and it's common for excess oil to bake onto it and render the units useless.
K&N filters are unfortunately an oiled set-up, most Japanese brands are note.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
