  • Replies 47
50 mins to put the stock Airbox back in?? LOL did you use your teeth? haha.
Iv just done the same thing, i switched back to Stock Dump/Front because the JJR piece of shit split was causing so much trouble. Now its running perfect.
At the same time i put my stock airbox and an Apexi panel filter in (had the Apexi Pod)
Overall im dam impressed. The sound is so much better, hear that turbo spool, and if your that way inclined, you can still hear induction and the BOV too. Think ill stick to the panel filter from now on. I like it.
Yep 50 mins (including the 30min i let her cool before starting any work). Been a nearly a week now and i am still impressed with the stock airbox.
x2. Love the sound too.
Just run 13.7'sET today. Reasonably happy with that, reeeally hot day and only VHT'd once in the morning :P
Wonder if there would have been any difference with the Pod..
  • 3 months later...
sorry to dig up this thread again, but i have now got an apexi hi-flow pannel filter in the stock airbox, i was thinking wouldnt it be better to actually remove the top of the airbox ? has anyone done this if so how did it go?
as long as the filter is secured with some cable tie or something it should mean better air intake if im right??
That defeats the purpose as its sucking in all the hot air from the engine bay. You might as well use a pod.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
