There was a bloke in Sydney doing it for a while. But I've sent him a few emails/PM's and hasn't bothered to reply.
I've heard that the biggest hurdle is working out the programming for it, as using the R32 ECU on the R33 uses a different K factor in the programming.
Don't ask me what this means cause it's way over my head. But it's not as simple as loading the factory R33 maps into the R32 ECU. There's other things that need to be modified in the programming to make it work.
Sadly it's not a straight forward process :)
J
  • Replies 43
nissan ECUs dont only have maps but have constants for different things like automatic, manual loading and many other things which no one really knows (yet)
currently someone i know is writing a software simulator to work out what everything does on an R31 ECU
K constant is for base injector pulsewidth and would of course be different between R32/R33 ECUs
Thank you Jay95R33. Hi GTST.
I can program chip for R33. It's like a min's ECU. Call one time chip.
If you change your mods I can make another chip.
But we have to import the chip from Japan each time, GTST where can I buy HITACH chip ?
I will get five chip at the end of this month from Japan and I will be able to sell programed chip. Price $350
If some one is interested, please send me PM.
I can get a daughterboard from Japan.
It's making only one company.
Cost about $300 - 350 (only daughterboard )and shipping , tax, install, chip tune.
Originally posted by Toshi
I can make chip for R33. It's like a min's ECU. Call one time chip.
Sounds good this^^^ one! Nothing like a little homegrown ingenuity...
but like i said before.
you wont get it right first time. You'll neeed to have 2-3 shots on a dyno to get a good tune and that (wil the throw away chip) will cost a fair amount of $$$.
But if you can get daughterboards (like mine) then that's a whole different case.
Yeah, the website was playing up last night, looked like it came through three times.
The R32 has gone to finance my wedding. I really miss that car.
The R33 is a result of finding the extra funds once all the planning and preparations were done.
I wanted my R32 back but it was to no avail.
Let's just say the honeymoon will be cut short but i don't mind.
I was so depressed without a Skyline.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
