Yes, if you've got easy access to the injectors its worth getting them cleaned and flowed. Mine were blocked even though it hadn't manifested in pinging or rough idle yet. I haven't driven my car yet so I can't comment on the difference, but I remember on SDU people were raving about smoother throttle control, smoother running and better fuel economy after cleaning injectors.
I can highly reconmend EFIS in East Vic Park (as referred to me by Steve-SST). Don't know how much they charge to clean injectors but they were reasonable in fixing up a stuff up another injector place made with my injectors.
I have a bunch of 25% off vouchers for EFIS that you are welcome to. Don't know if they're still valid though.
What did united mean by "leak in the middle"? The middle injectors in the fuel rail leaking? Or some fault in the centre of a injector making it leak? EFIS pressure tested my rail once the injectors were back in and none of them leaked.
https://www.sau.com.au/forums/topic/24625-injectors/#findComment-524757
I havent really got easy access to the injectors still have the stock plenum in the way. I was just thinking it'd be worth pulling them out, cleaning them and checking the flow before I start leaning on the engine with the ecu tune. I think I might try these people, how/when can I get one of those vouchers off you gradenko?
https://www.sau.com.au/forums/topic/24625-injectors/#findComment-525464
rob77, I'd be hesitant to remove the plenum just to get to the injectors. Pulling the plenum is an absolute PITA, so only do it if you have to. Unbelievably the gasket between the upper and lower plenum in $85 from Nissan.
I think rev210 has removed injectors with the plenum still on, so give that a go and pm him if you get stuck. ;)
https://www.sau.com.au/forums/topic/24625-injectors/#findComment-525612
R32-GTS, maybe the rb20 plenum has bolts in different locations, but theres no way you're going to pull a rb25det plenum in 20 minutes.
Just buy a new manifold gasket from nissan that costs 10 bucks.
?? Have you priced these for the rb25det? They're not $10.
https://www.sau.com.au/forums/topic/24625-injectors/#findComment-526016
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
