Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
Hi guys,
Having a hard time working out what I want for my car.
Before I get into this... YES i have searched, found some info but didn't match what I was after... or was uncompleted "Il post my dyno results next week" and then nothing, all the threads had HEAPS of opinions but no facts or proof, since these threads come up all the time id like to compile a thread which will end all
Had a nice 2860-7 set-up planned for the car.. While stripping her, one of the coolant flare nuts seized... Result? Yanked the motor, opened her and started building her..
-26 block, 20 thou over
-HKS dove cut 86.5mm pistons
-fully prepped 33 crank
-eagle rods
-Genuine nissan bearings
-studs etc
-HKS full gasket kit
-N1 oil pump (at this stage, might upgrade to Tomei or Jun)
-N1 water pump
-jun baffle
-freshened up head
-new valve springs & guides
-in and ex hks 280 degree 10.2 lift step 2 camshafts
-HKS cam gears
-new balancer (yet to purchase)
bla bla bla
got a tial 44mm gate ready, 800cc injectors and 1x 044 (will need another for the Z and a cooler)
Compression ratio is going to remain very close if not standard atm..
Unsure if I want to go for a GT35R (1.06 housing, mech gave me the option of switching to .82 if i find it laggy)
or
a Garrett T04z..
Really confused atm.. Everyone is telling me different things;
-Garrett T04z's are crap
-The T04z will spool much quicker
etc etc... Its not one sided so im having great difficulty here.. I just want the car to be perfect for me..
It's a street car which I track and hill climb, im trying to get serious with my motorsport so don't want a lag monster, but understand that I will in both cases experience lag.. unsure if the extra power of the Z will offset the lag in satisfaction.
Looking for about 400kw on high boost.
Any info, or more so experiences would be great..
Have NFI how any of these perform on a stock capacity 26. I do not want to make the wrong decision.
Appreciate the info!
T04Z is a 440-450rwkw turbo
GT35 is 350-380 give/take
So i'm not sure where you get they are the same, will spool earlier or whatever.
GT35 is smaller. Therefore its going to be more responsive.
If you dont want a laggy car, then a T04Z is not for you, simple as that. You want the GT35 in a .82 or a set of -5's
.82 35r will do 400rwkw no problem. If you plan on doing tight 1-2nd gear work (most wa events) and want to be remotely quick I think even the 35r is too large.
a GT40R or GT4094R is a closer comparrison to a TO4Z, like Nismoid said, the GT35R is a smaller turbo.
also remember bearing desing on the GT series is a whole generation newer than on the TO4Z
People have used the TO4Z with great success on a stock capacity RB26
To give you an idea on the difference have a look at the dyno thread and find these users
T04GTR, DVS32R, CruiseLiner, Cerbera, R32-GTS, overpowered all run TO4Zs and all make well over 375kw
have a look and compare the powercurves of these turbos with your original choice of -7s.
You will find that the -7s will come on harder earlier, making your car suited to your original intent of track and hillclimb work. I would imagine that the single that get closest to power delivery of -7s would be a GT30R. But if you want more grunt go for the T04Z or GT equivalent, just dont expect it to be suited to short tight hillclimbs
No doubt they are animals, but when response counts (if the courses are indeed as tight as above) then you really want -7/GT30 style setups for max response, you'll be faster that way ;)
  • Like 1
i got t04z 1.00 getting tuned next week, not a full daily so didnt bother me, but if it was pretty much everyday street dont go t04z, unless u love a super hard hit but alot later hehe
t04z is in no way older technology that gt35, maybe theres confusion with the old t04e/s/r types, its an extremely quality turbo
Anna (msnismo) just upgraded from a GT3540 to a T04Z (RB25), being built buy dave (T04GTR) this week. I suggest if you're really having trouble deciding that you shoot Anna a PM. :P
Ash was pretty much spot on with his power ranges though... The T04Z will crack 400kw but will be pretty laggy (expect to spend most if not all of your time above 5krpm) and the GT3540 will be more responsive, but you'll have to ring it's neck to get the kind of power you want (don't think you will get it up to 400).
If you're already set up for twins, I would seriously think about keeping it that way. :laugh:
Yes it is, the core is the same tech as the GT35R but the wheels are pretty much the same as an old T67. Yuck things, though work really well on 3litres - probably as much as anything as by 3litres you are getting to the point that anything which isn't completely stupid will work well.
Ye the T04Z is by no means startling decent in terms of tech as above - older wheels.
I'd be looking @ GT40R instead of a T04Z - Discopotato has posted his usual degree of superb information on this already
t04z too laggy for any track work unless its a big open circuit event and u like keeping it above 4500rpm all day, even the gt3540 ive seen isnt that much nicer response wise. If u plan any sort of motorkana/tight track events its gotta be a smaller setup, dont think u will get 400kw and fly around tight corners, it just doesnt happen. I would go a 3082 for high 400hp figures but plenty of response, and for low 400hp but super response go the 3076r.
having shitloads of power is overrated imo, reading sites like this and everyone has a different opinion on how bad the lag is on certain turbos. If u have your car in 4th gear at 2500rpm and u plant it and u gotta wait till 4500rpm for it to go fast its a loooooong wait i can tell u that, on tight motorkana tracks u cant drop down a gear unless u wanna be in 1st gear most of the time.
thats my opinion anyway :P
  • Like 1
Ive had both t67 and td07s on my 3L and they are NOTHING like a t04z. At work also have a a t67 rb25 and a t04z .84 split housing rb25.
T04z's as mentioned have had heaps of success of stock capacity rb26 and rb25's. a T04z will need other parts to help it work efficiently, cams, etc etc, dont expect to just slap one on and it all works absolutley perfect, where as some of our gt35rs have worked sensational just bolted up.
if the technology ur refering to by old technology is the P trim exhaust wheel, yes the new one still uses that but its been highly refined and updated they have less blades and different pitch cant tell me they are the same, to say it uses old technology would be to that they havent refined the P trim at all since the early days. it also has the same bearing system as the gt42
as mentioned 2 totally different turbos
but people can have their own opinions i just go by what i have/had and experience
ben...
Edited by 2BNVS
or
a Garrett T04z..
The 1.06 housing is going to be far to large for the stuart hillclimbs and the bitumen sprints. Definetely go the .82 on the GT35 if your serious about these events and are set on only one of those options, even that im thinking might not be as resposive as you would want.
Richard has the garrett TO4z on his supra in a .82 im pretty sure (not sure if you knew rich) and it was the same response as having the orginal twins setup as a true twin system, not the sequential setup. It wasn't too laggy however that's obviously on a 3L.
Most even comparisson I can find between a T04Z and GT35, similar exhaust housings (both ~.8)
Similar boost levels (T04Z = 24psi, GT35 = 25psi). No porting on either, similar cam duration and lift.
400kw is just a nice figure I threw out, if it comes close il be happy.
Reason I have posted this thread is due to the "opinion" I keep hearing
"T04z is a much better designed, even with the bigger wheel it is not as laggy as a GT35R"
etc etc
Only a few people have shown or proven me anything, it's really hard to feel comfortable spending $1000's on a set-up which is not proven.
Im leaning towards the GT35R, the -7's are out of the question
Hey Paul,
any more info on the builds of these vehicles? Thanks for the graph
Blue line is Cerbera's.
2.6L, JUN 270deg cams, 2nd hand pistons. Very basic build.
Red line is Nik's (DCIEVE).
Not as sure on the specific's of his build, but it is a standard displacement 2.6L.
The reason I used Cerbera's T04Z graph instead of Simons (R32-GTS) is because Simon's has extensive head porting to make it come on song a lot earlier.
I am currently upgrading my Single Apexi IHI RX-6 TCW77P25 (makes 300kw on 20psi (lol or 24psi doesnt make any more HP as it cant flow anymore)) and is massively responsive!!! Makes the car very fast around the circuit.
I have gambled and am going for a GT35 .82 rear on a reasonably simple rb26. Will post my results next week. Aim is 350kw on 20psi But I am happy to sacrifice up top for as much down low as possible...
Car is only used for circuit, want to do some hill climbs etc too, which I think I might find it a bit laggy but hell, will soon see....
Michael
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
