Booked the car in last week to have the timing belt and water pump changed...
Have to say I couldnt recommend these guys enough, they did it all with ease, even fitted a GTR n1 pump...
I went off to a confrence in the morning and picked it up just after 5 in the arfternoon... They were extremely helpfull and i'll be getting all my work done there in the future...
They can do pretty much anything I think, so give them a call next time your in the market for some mech work!
https://www.sau.com.au/forums/topic/24652-gavin-woods-auto-tech/
  • Replies 181
Agreed.
I recently had a heap of mods installed by Gavin and his team.
He also found other issues that I got him to fix too. It cost me, but in the end better than something major happening, and relieved that he found them at all.
I had my Apexi PFC installed by another mob in Brisbane - and apparently they left it a base tune. Grrr.
After Gavin properly tuned the ECU, the car feels great.
They get my business from now on.
here here...
I've owned my car coming on 3 and half years and Gavin is the only person other than me to have worked ondriven it.
We've been through exhaust sensors reading 4000 deg to cracking an exhaust manifold in half...I also, can't recommend him enough and am sure there will be many a good post to follow.
Well I travelled 30 hrs down and back from Townsville to see Gavin and he definately gets my vote the guy and his team were fantastic. He accomadated us very well taking the time out when i arrived to go through all the gear i had (quite a bit) for him to fit to my car and he understood that i was pushed for time and had to get back to townsville for work so just concentrated on my car for two weeks so it would be finished, he is definitely a dying breed in the auto industry where customer satisfaction comes first . :D
Oh, here we go.. Now everyone wants to blow his horn eh?
I've been saying for over a year that Gavin is the man for Nissan + tuning + service and people have said "no go to this place".
Meh, they are more friends to me now than a mechanic :)
Christmas card buddies.. you know the story :)
Best. Mechanic. Ever.
Still no one understands why I drive to laborador to get my car fixed/serviced. Now you all know why.
And if it wasn't for me sitting here saying "GO TO GAVIN... GO TO GAVIN" no one would have known about him :)
You all know how much I baby my car, and for me to trust him or any of the other mechanics in his workshops says a lot :)
We also need to give recommendation to the other guys in the workshop. They seem to be forgotten when people say "Gavin Woods" yet the other guys do most of the work while gavins off in other parts of the country doing tuning :)
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
