Maybe someone can clear a couple of things up for me..
Ive read when tuning the fuel maps with the PFC that the O2 feedback should be turned off. ok, but should it be turned back on after tuning is finished ?
Also, the o2 feedback loop, is it more economical to run with it on or off ?
:P
https://www.sau.com.au/forums/topic/246590-o2-feedback/
i find with mine turned on it used to retart the ignition when u booted it and back teh fuel out
the tune on the car was farcked anyway what i have to loose i guess
turned it off again
and it would rev beter
not trying to lean it out etc
my engin prefers t run a little rich
https://www.sau.com.au/forums/topic/246590-o2-feedback/#findComment-4286129
typically on when driving normally
it should be off when wideband tuning your car
in most scenarios you will get good economy with it on and a basic tune
if you have an aggressive tune and the tuner has spent lots of time on light cruise with a wideband sensor
you can get better economy with the 02 feedback off - you can also adjust the 02 feedback co-efficient
so its not just a fixed "stuck at 14.7" setting if that makes sense
https://www.sau.com.au/forums/topic/246590-o2-feedback/#findComment-4286149
Ok, so when its on, are the maps setup on the pfc ignored?
Reason i ask, when on monitor, i dont see the ign timing that the map is set to for that specific rpm. ie the map is set to 28' ign for idle yet under monitor the timing is 15' ... this is with feedback on.
https://www.sau.com.au/forums/topic/246590-o2-feedback/#findComment-4288525
Closed Loop running doesn't affect the ignition timing, only the fuel delivery. You should notice the fuel ms varying (at cruise only!).
Closed Loop attempts to run the engine at 14.7 AFR by continually reading the O2 sensor output and adjusting the fuel delivery. Because it is reactive, rather than predictive, it continually overshoots 14.7, so the AFR actually cycles between "> 14.7" and "< 14.7" AFR.
https://www.sau.com.au/forums/topic/246590-o2-feedback/#findComment-4288627
For the government emissions test they have a low idle and a hight idle test (high idle being they hold the engine to approx 2750rpm).
My car is failing on high idle on carbon monoxide, whether feedback is on or off.
Anyone know if i took fuel out of the cells around that point will it bring the CO down?
Or do I have to put the cat back in (de-cat pipe fitted), in order to pass this damn test? :P
https://www.sau.com.au/forums/topic/246590-o2-feedback/#findComment-4294155
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
