Front diff, front CV joint or semi siezed wheel bearing at a guess. Maybe jack the front of tha car up and check for any freeplay / noises from the front wheels one at a time. This is kinda a hard one to diagnose without seeing it. Where abouts are you located?
https://www.sau.com.au/forums/topic/246627-need-help/#findComment-4286676
Hey guys
S1 series stag, when reversing with full lock the outside wheel makes a grinding noise and seems to bounce
been to a few garages noboby in vic seems to know what they are talking about, any comments would be a great help :blink:
Had the same thing in past.
Would not always happen, but when it did happen, the fear of god was put into my wallet.
Funny thing is that when I upgraded my wheels from 17" to 18", the noise stopped.
odd.
https://www.sau.com.au/forums/topic/246627-need-help/#findComment-4286958
Already had the front drive shaft replaced 'mechanics theory' located in victoria.
https://www.sau.com.au/forums/topic/246627-need-help/#findComment-4288069
:huh: I didn't mention the front drive shaft.
the front drive shaft cant really have anything to do with it - there is an open centre diff and CV joints between there and the wheels.....
https://www.sau.com.au/forums/topic/246627-need-help/#findComment-4289108
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
