I have seen oil surge in my R33GTS25t, I have 225/60x16s, DBA slotted rotors with EBC greenstuff. On hard stop from 60-70 kph with a full stop (ABS active) the oil light will flash for less than a second as the car stops!!!!
Better baffles or accusump are the only things that will really fix it, I drive round the problem at present but would like a cheap effective fix.
  • Replies 48
Most good speed shops should stock them. There are numerous places in Sydney.
From an independent US motorsport supplier...
The best and original coolers for motorsport, fitted as original equipment by most leading manufacturers, McLaren, Penske, Lotus etc.
Just bought one:) told me dimensions are 300 x 250 so not as huge as they look in the photos, besides a bit of extra oil never hurt anyone.
they use 3/4" banjo fittings (supplied) and the coolers are made by Serck;)
the guy told me that they are the same one Nismo use for their N1 models
Steve, Let me know how it goes, I plan on getting an oil cooler soon.
If you fit a fast acting oil pressure gauge you'll see that the RB25's suffer from oil surge just like the RB26's.
I think Sydneykid can modify the exisiting sump for extra capacity etc.
Paul, shall do, big cooler means extra oil volume too, cant hurt.
Brendan, definately will be fitting thermostat and remote filter, just need to fine some:) I am looking for a remote filter with thermostat, rather than inline sererate thermostat, but it is proving rather illusive. got quoted $20 per foot for braided 1/2" line from OG speed shop - going to have a look tomorrow.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
