  • Replies 48
For my cooler i used some high pressure hydrolic hose from work, its rubber hose with double layer of braiding, rated to 4000psi and a few hunded degrees. It dont look as flash as the other stuff but is a bit cheaper and would better quality.
Based on what i paid for Speedflow fittings, there is about $430 for fittings in that photo, + $30/mtr for braided line. I used a Earls remote filler adaptors, doesnt have thermostat or relief valve but cost well under $100 for both.
Living in a fairly moderate climate is there a point to having the thermostat?
