2530 off, fmic is ok if you haven't cut into the reo bar, or chassis, and it is secure, secured pod is fine as long as it is secured tight, 3'' exhaust will probably have to go as it will be too loud, power fc will have to go, for safety sake the boost guage will have to go, as it is probably in the line of sight, 555's regency may just pick on, fuel pump is ok, afm will need to change as you will be taking out the power fc, boost tee has to go, and nardi steering wheel probably isnt ADR compliant so that has to go.
Good luck!
Aww man thats the biggest headf**k ever
can the power fc controller just be removed and the ecu left alone or does the whole thing have to come out?
defects suck (N)
quick question, dump pipes allowed?
mate just went through with his 3" dump pipe and cat on, but with a factory system from the cat??
you can go through with a full zorst as long as it is under the legal DB limit......i went through with mine just had it quietened down and presto.....so the exhaust size doesnt matter...
will a s2 turbo pass through regency or will it need to be the s1 r33 turbo?
I think your series 2 turbo should pass fine as they look identical externally and it is a factory Nissan part. But make sure all factory boost lines are in stock positions and you are not running any bleed valves or T pieces or ebc. Just run the factory boost solenoid wired on standard mode not on high boost mode all the time. And all should be sweet!! good luck :P
They dont take the cover of the ECU to see if its stock. but they do now look for holes for the hand controller. thats how they got me last time I went through. If they find that they automatically think you have a Z32
Good luck!
injectors will have to come out as the stock ecu cant run them.. unless u get a remap but thats $500
OR you could try putting your stock ecu cover over the top ond the power fc one and try your luck.. then afm, injectors can stay in..
they may or maynot check it..
i have been through MANY times and not even checked the ecu!
when i took my skyline through, i had my high flow on there with no heat shroud.. fmic full 3" tien high adjust AND PASSED!
they arent that picky.. they just check if roadworthy mainly unless suspicion of engine mods
Yes... they are. You got lucky
Rang up today to book my car into regency and was told that a new place at Lonsdale is opening up to clear defects on Wednesday's and Thursday's so i've got my car booked in for next Wednesday. Hopefully the guys who work there are chill.
Yeah def let us know how it goes!
Us down south need a place this way to get us off defect!
Hey, im taking my down to Sinergy for a pre inspection, but the rego has run out. Do i have to get a permit to drive it there or should i be fine.
Yep you definitely need a permit mate.....just do it on the day of your inspection and get the permit to go to sinergy first then to regency and back home .....if not the refer to VVVV
if you're thinking of driving it there unregistered, i hope you carry a spare jar of vaseline with you.
Just a quick question will a vg30 turbo pass regency as i really dont plan on doing this all again and rather have a hiflowed vg30 as opposed to a 2530?
Cheers, Chris
Yep it should pass without a problem mate....its a Nissan OEM part so not defectable....one would assume...
hmmm i think they will know that its not a stock skyline turbo.....
Nissan OEM parts are not illegal to have :P
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
