Just a quick question.
If i get an engine rebuild with all the internals done like pistons head work etc and the stock turbo rebuilt if for some reason i have to go threw regency will they pick up on this at all?
Would they be able to tell whats been done to the motor and turbo seeing as will still look ''stock''?
If you change the cams, they'll be able to notice it by the idle, if not the emissions (if they do an emissions test that is).
Stock turbos rebuilt with steel wheels will be undetectable if theyre in the stock turbo housing however you wont be able to have a boost controller fitted as that is a defectable mod.
Depends on how stock you go - obviously getting new gaskets, seals, springs, forged internals etc are just replacement parts but if they suspect you've worked the engine they can quite easily suggest an emissions test - and lumpy cams are a dead giveaway
-D
I had a rebuilt rb25det and a highflowed gcg turbo. Now the turbo looked brand new as it had been sandblasted, I made sure to remove the GCG logo and just told the guy it was rebuilt to standard specs.
As far as the motor theres no way in hell they are going to know if its got forged pistons or not, I know they couldn't tell with me.
-D
im running cams with a lumpy idle and i didn't have a problem at all when i went through regency
Guess you were lucky then dude... knowing regency, I wouldnt give them the rope to hang me with...
Also, a customer of my mechanics had a very lumpy cam put into his commodore - 3 weeks later he was defected because the police officer suspected modification (due to the idle creep) and sent him down to regency who then told him he could only keep the cams if it passes the emissions test.
No idea if he had the test done as I've heard that emissions tests arent cheap - just think its something to be wary of.
Like Damo said tho, they wont strip ur engine apart to see whats in it, but its really not hard to chuck a gas analyzer on the exhaust and see how its running...
-D
-D
hmm ok but what do u mean by throwing a gas analyzer on the exhaust to see how its running? high emmisions from the cam? :S
well im not a mechanic, but from what i understand, modding the cams changes the efficiency curve, ie it might burn richer at lower rpms but be geared for upper end power...
each car has a certain emissions target due to the standards of the day, and so regency sometimes use this as an excuse
a gas analyzer will not only tell the air fuel ratio but how many hydrocarbons are being generated and what type they are - again I don't know the details but like the others have said, forged internals will be fine - its more cam and ignition timing that changes the efficiency of the engine under certain conditions
this bloke with the v8 was pretty pissed off cause changing cams on his particular engine wasn't anywhere near as easy as doing a DOHC engine like an RB
-D
-D
Regency don't do the emission test themselves so i dont think you really need to worry about it. my car passed and it idles at 1000rpm when it should only be 600rpm or so. If you fit a standard exhaust they wont be able to notice as easily.
Depending on the type of the piston used the dome design might lower/raise compression, it might also change the burn characteristics so that you get different emissions.
Most workshops will dodge something up for you though as they know regency will only check if the values are absurd.
