From my experience with him, he seems like a fairly decent guy just doing his job.
And he explained why the bc and wheel studs were illegal. Then gave me an opportunity to fix it up. Can't ask for more than that I guess?
:cool:
saturday nite... drive my pos even tho i knew i shouldnt have
pulled up in a servo on the phone. stopped at the entrance. car pulls up behind me and waits. i look a bit closer its a cop car...
anyways, i take off to go park next to an ultimate pump (2x 90deg turns) and hear my awesome diff doing its thing chirping its tits off on the smooth surface haha.
they pull up next to me. gimme a death stare, i jump out, "how can i help you officer?" get a reply "Regency for you mate" i look confised... "whys that?" :P he asks me for my license, then tells me "just go home, dont be an idiot" and leaves.
so here i am left standing with a roll cage, locked diff, slammed, wheels, straight through twin pipe, in primer with rivets in the rear quarter and zipties holding the thing together.
not a bad nite lol.
sounds to me like some of us are getting a little bit of a break, they're not cracking down as hard on skylines it seems?
it probably helps when the cop see's that you're not an idiot.
I don't think it is that different from a couple of years ago.
I reckon that is the main thing.
If you are a dick, and stand-offish, and argue, then you won't get any chances.
That's not to say you can't ask questions, but be civil about it.
If they see you are a decent person they usually give you one chance.
My experience with cops in general actually. If you know you've done something wrong, don't argue. And even if you haven't, don't be a dickhead :cool:
i got pulled over 3 times on a friday night within 2 hours and neither time they asked me about my car
was polite and just chatted to em
meanwhile just sittin there tuckin rim with straight pipes that hang about a foot out the back
Hey guys i'm getting a Wide body kit for my R32 carbon fiber with a carbon fiber bonnet,
I'v hidden my boost gauge in the dash u literally need to pull whole dash out to get to it, Was wanting to know how much shit i would get into if i got pulled over,
depends on the carbon fiber. if its dual layer and kevlar backed then it is legal. you still need to get an engineer to have a look at it and note down any changes in your guard eyebrow height (im assuming you got widebody guards) and change them accordingly before regency will approve it.
if its just kinezi carbon fibre then no it wont ever be legal as its a major safety risk should you hit a pedestrian or something as cf without any backing just shatters in to shards and causes an unnecessary safety risk.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
