Rather than start a whole new thread figured i'd ask this here...
Has anyone ever been picked on for having retreads when going through Regency?....Im going tomorrow and I just noticed on my Tire Placard in the fine print that my GTR requires a 'V' Rated tire 240km/h....my intention was to borrow a set of 33 stockies with retreads...has anyone ever been shafted for this?
you will be fine with those mate. As long as the tire has tread and the wheel matches the size stated in your placard you will be fine.
goodluck
Just a quick update, passed inspection today, think i scored the best Inspector there...only down side was I broke the connector off my PFC Hand Controller, I had left it in the car as it wasnt connected and me and the Inpsector exchanged views on the matter...I got a little frustrated and pulled a bit harder than I should have and it broke...exhaust was super quiet, went to 92Db then settled at 86Db...full jap system with metal cat too...wtf? Does have 2 big mufflers...Anyway, im sure it can be fixed, stoked to have passed!
Anyone know anyone that fixes PFC Hand Controllers???...
Any electronics repair business should be able to solder you up a new connector, unless you snapped the actual physical plug itself, might be pretty hard to find a replacement, though any decent electronic technician could wire you up a different plug,
  • 1 month later...
Is the panel firmly attached or does it flap around? If its firmly attached you might be ok, just depends on inspector.
I had my inner guards hacked to pieces, rear bumper loose (they didn't touch it) and front quarter panel had a crack where it mounts and was cable tied on (also didn't touch it), didn't get picked up however none were obvious or loose panels, yours has a hole so it might get picked on.
gday all had my pride and joy defected a few months ago for being 10mm too low and a broken fog light near the underpass of ingle farm shopping centre....was wondering how with the fact of stock springs? as i wasnt driving the car it was a spastic ex that has no clue i couldnt dispute it. and on the subject of fog lights why defect it if you cant use them for city driving? fairly furious and whether i could escape with taking it too elizabeth cop shop?
Edited by gilly_ECR33
Need help asap. Did a final check over the 33 today getting ready for regency in the morning an now as soon as i indicator the hazzards go on.
I have replaced the flasher relay
the fusses
the globes with corect wattige
Have ripped dash apart looking for something earthing i am stuck and have no clue what it could be
345 up front 355 rear got re defected for height today at regency gay not happy so am now after front and rear struts
What height is it now?
I'm a bit worried about mine now too - since I put the 18's on it seems to be sitting around 335 - used to be 345-350-ish :( .. guess I can always put the 17's back on to get through..
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
