V8 v R33 GTR
102 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
hi i do under stand that this is a skyline website and i my self have a skyline and it is my pride and joy
but just putting a hypothetical out there lets say that u were offered a R33 GTR for free stock and no strings attached
but then the person giving u the car says that for free they will put a V8 like the ford aluminum 4.8L DOHC or GM small block that is similar u get the idea
would u keep it stock or will u get the V8
this is my first poll so soz if i stuffed it up
https://www.sau.com.au/forums/topic/247034-v8-v-r33-gtr/
  • Replies 60
Your saying that someone would actually swap the legendary rb26 for a GM or ford v8? does that include the 7litre ls engine they put in the corvette?
The new zr1 engine puts out 600+ hp so that wouls be my choice but if its just the crappy 5.7, 4.8litre engines then id rather the stock rb26.
lol stock r33 for sure haha
https://www.sau.com.au/forums/topic/247034-v8-v-r33-gtr/#findComment-4292683
the V8 has to be a small block because in the real world a big block will be real hard to fit in a skyline
ford sell out of the box motors fully dressed with +500hp and it is a small block and good for daly driving
http://www.fordracingparts.com/crateengine/modularcobra.asp
so the small blocks can put out a bit more power then ppl give them credit for
or on the other hand u can go with a RB26 which is still real good
https://www.sau.com.au/forums/topic/247034-v8-v-r33-gtr/#findComment-4292753
If I took the LS2 from my 07 clubby and put it in a 33 gtr, I don't think I would be lacking in smiles when the foot goes down :) No doubt more response everywhere then stock 33 gtr with stock rb26.
https://www.sau.com.au/forums/topic/247034-v8-v-r33-gtr/#findComment-4292785
if still 4wd, then v8. if not, then stock.
what makes you ask this? is it ever going to happen? bit random.... or are you thinkin of putting a V8 in one but too ashamed to admit it?
as a side note, someone up in sydney is building a VH41 (45?) power R32 GTR, still retaining the 4wd, with a couple of turbos thrown in for good measure. i think its performance metalcraft that are doing it..... cant remember now though
https://www.sau.com.au/forums/topic/247034-v8-v-r33-gtr/#findComment-4293788
If the V8 can somehow be adapted to work with the ATESSA then I'd take the V8. Otherwise I'll stick with the RB26 and ATESSA (what good is lots of power without traction?).
fun thats what!
there are millions of r33's out there so do it, be different
some guy on boostcruising put a nissan v8 (not sure of the name of the engine) into his r33 it was doing low 12's from memory
Edited by thorpe84
https://www.sau.com.au/forums/topic/247034-v8-v-r33-gtr/#findComment-4294362
RB26 all the way.
Thats the reason for turbo chargers, don't need all those Cubic Inches IMO.
And whatever top end you can achive with a V8, you can do the same with a 2.6lt Straight 6 Twin Turbo.
Thats how I see it anyway, I enjoy the feeling of the boost kicking and high reving cars.
https://www.sau.com.au/forums/topic/247034-v8-v-r33-gtr/#findComment-4294361
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
