Hi i have owned this car for 4 years now and have decied its time to move on so its up for sale.
R32 GTR 1989 model
190k kms on the tacho about 20k kms on the engine and most parts
black in colour
Price 30k
engine
87mm Arias forged pistons
P.A.R billet rods with 7/16 rod bolts
ACL race bearing
Crank balanced,grub screwed and JUN crank collar
block acid bath, decked and oil returns bored out.
Head rebuilt fitted with bronze value guides.
Metal head gasket.
Modified sump larger and fitted with tomei sump baffles.
Covers have been coated by Craved and new R34 Nur centre plate.
JJR catch can
SARD 800cc injectors
SARD FPR
Tomei 260in/out cams
HKS cam gears
Gates timming belt
N1 oil pump
N1 water pump
Nismo oil cap
Nismo harmonic balancer
Nismo fuel pump
Nismo AFMs
Nismo engine mounts
Ms/k&n air pods
Apexi power FC
Turbo
HKS 2530 turbos currently tuned to 21psi
HKS dump pipes
JJR front pipes
high flow cate
kakimoto exhaust
Cooling
JJR 40mm radiator
JJR silcon radiator hoses
JJR cooler piping
JJR 100mm inter cooler
JJR oil cooler(not fitted)
Nismo radiator cap
Handling
GAB coilovers
Cusco strut brace front and rear
Steering rack rebuilt 20k kms ago
exterior
18x10+18 WORKs XD9
Work blue wheel nuts
Nankang NSII 265/35 tyres
N1 front bar vents
QFM 750 brake pads
slotted discs
standard GTR brakes
Nismo fuel cap
Interior
Nismo gear knob
Nismo Steering wheel
Blitz ID III boost controler
Apexi 60mm boost gauge
MP3/CD stero
Think thats all i can think of right now sure i have forgot a few things .
There are some bad points car has a small dent on bonnet and drivers door plus a small tear in drivers seat and non work AC.
Im in no hurry to sell this car i may keep it as the next thing to do is respray it and it wuld be perfect
No silly offers price is 30k i dont care what others are selling for, car Ran 11.693@116mph on the 19/11 probly could do a little better but who knows.
Was one of the top cars on the skid pan last Texi and has only been to wakefield once with no timing.
Oil is change every 5000kms by DART Automotive who built the engine. Car was Tuned 500kms ago by Unigroup was tuned for power under the curve not peak power.
Also have some other parts like HKS twin exhuast and 17s.
Plates dont come with the Car tho if you want them Pm me an offer.
Contact via PM, [email protected] no Mob number as i work shift work will give my number to anyone who ask for it.
Price 30k
https://www.sau.com.au/forums/topic/247256-heavily-modified-r32-gtr/
This car makes some scary power!!!
I've seen the car go from pretty stock to a pretty rocket.
Who ever buys this is definately getting a bargain!!!! It's pretty much a new car!
Bumpity Bump.
This is an awesome car, have been in it many times and its so fast it absolutely scares the CRAP out of me. 30k is a bargain when you consider all the top quality parts and effort put into this build.
Id buy this in a second myself if I had a spare 30k lying around.
  • 3 months later...
this is a beautiful gtr - i ran an 11.1sec with 5kw less than what u have here just to give others a better idea of your cars capability
dart has always been my choice of mechanic :devil:
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
