Hi all,
i currently run a Greedy emanage on my r32 GTR and want to change over to a Power FC
A well known Sydney workshop has advised they can use a PFC from a R34 and change some wires and it will work on my car. He has a 2nd hand unit and has made it very compelling from a $$$ perspecetive.
I know that the 32 and 33 PFC's work and usually not the 34 version.
Does anyone know if this has been successfully done before? I dont want to be the guinea pig for this.
thanks
Edited by mattblack
I'm sure it can be done, but how cheap is this power FC? because 32/33 power FCs are not exactly stupidly expensive. they are probably the most affordable ecu you can buy and one of the most common types of PFC out there. so the 34 one would need to be mighty cheap to make it worth the hassle.
yeah he quoted me under $1000 supplied, installed and tuned. No hand controller though.
is this good? Im thinking yes
If the tune is good, then yeah that sounds cheap.
You should probably set an alarm on your phone to snipe this in the last 10 seconds:
http://cgi.ebay.com.au/apexi-power-fc-hand...%3A1|240%3A1318
it's ok, but really not super cheap. you can get a used PFC WITH hand controller for under $800 or less. and hand controller is important to have and expensive to buy on it's own.
i ended up getting it done but they decided to use one specifically for an R32 GTR. They spend 3 hours tuning it with 4 boost levels so i feel i got a good deal.
I have to say they did an awesome job on the tune, the car is much more responsive to throttle inputs and heaps less laggy with good progressive torque down low.
I will post the dyno printout but a quick summary saw me get the same power output on 14psi that i was previously achieving on 19psi with the Emanage. On 19psi i gained 26.2kw atw so now it has 311.2kw atw. There is more in it but i wanted it on the safer side.
Thanks to everyone for your comments and advise. this is a great forum thanks to you guys.
cheers
MAtt
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
