  • Replies 719
I'm using it as an excuse to justify replacing the standard swaybars with adjustable Whiteline bars.
It only hits when you've got it all loaded up in the middle of a corner and you hit a decent bump. I'm hoping the sway bars will increase roll resistance enough to stop it happening. Doesn't happen at QR or on the road, just those 2 spots at Lakeside - both have decent bumps in them when the car is all loaded up on that side.
If that doesn't work I'll look at other options. but I don't fancy relocating the loom...
well except then you either rub through loom, or fit plate and rub through tyre.
best bet is relocate the loom.
LOL
I have been a victim in my 32 at the circuit. ;)
learnt lesson, relocated now!
im looking forward to this. out of curiosity, for those who have done both winton and oran park can you put up your times. basic theory is that winton is the closest thing to oran park we have down here and could be a rough indicator of times to be had..
Handbags belts out 36s at Winton and 17s at Oran Park. But his car is not exactly easy to use as a yard stick because the thing is such a wild thing to drive. So may be worthwhile considering a GT Production STI used to run 1:33 at Winton and at OP they run 1:16
email nathan@superlap Bryce he'll be able to help with that.
it's going to be a ripper. hell I may even make a fool of myself in a car that's way above my skill level... :P
Enter the Truck Beer Man!!!
lol, it's pace is on par with my skill level. still it might give that RX7 a shake up as he comes up pit lane the wrong way at me...
Ha,,Ha,, thats as funny as Baron,,,thats a car I was asked to drive. I can't see it happening now as we are about to have a little professional argument soon.
If I do still get to drive it,,,there will be none of those shenanigans,,,so you might have to not use the truck my good man.
Merry Christmas everybody.
Love as always
Neil.
Neil you mean it's wrong to drive the wrong way up pitlane? But I seen a well known tv personality/instructor do it last weekend in his ute so it must be ok....
No Ben nothings wrong till you get caught. You should know that!!!.
No I would never drive the right way on my mobile,,,then reverse back into my garage and then reverse down pit lane again. Did i get that right???.
Enjoy Christmas everybody
Neil.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
