heatshield for POD filter
cobo_11
 Share
  • Replies 54
Attached is a pic of my partition, made out of the metal backed foam, and topped with 'armourflex' pipe insulation.
Just used a manila folder to work out how it needed to be cut, then traced it onto the foam. It is a tight enough fit that it didnt need any brackets to hold it into place.
total cost was around $25 with enough foam to make 2 partitions.
Originally posted by Mr Rb20
What about running a cold air pipe from the bumper into the box or do you just leave the filter partitioned with no air running to it ??
If you dont have a cold air feed, it would probably rob you of power.
BOOSTD had back to dynos before and after and gained power by removing his partition.
With a cold air feed, different story altogether. Improved throttle response - best way to describe is on a hot day, the throttle response is more like it is first thing in the morning - if that makes sense?
Once you have a front mount, it frees up a nice hole to make the feed.
 Share
