Taking A Turbo Off For P Plates
+1. Good thing is people wont tailgate you for a while
If you have a RB25DET NEO AWD motor, you will need this: https://www.hioctanedirect.com/ASR-RB26-RWD-Street-Comp-6.5L-Sump-Suit-R32/33/34-and-VL It is made for the AWD motor, but makes it fit a RWD setup and gives you a new pickup. Just one thing, the pickup sits quite forward, compared to a conventional RB25DET RWD motor. This may or may not have contributed to my previous AWD -> RWD shitting the bed at the track. -
My car is also flex tuned. It's worth mentioning it (the LS1 ECU) has a 1D table for E85 addition and just uses the ethanol stoich part as the second point of reference. It also as a 3D timing map for Ethanol adjustment. You would think this isn't enough but it works pretty damn well. That said, I wouldn't want it in turbo application. It's like lifting non-natty, or taking meth. It gets you unrealistic results that break down more things going forward. If people used it to make the same amount of power they do on 98 then it'd be one thing. But people use it, crank it up to eleventy million PSI, it doesn't knock - but it pushes the point of failure to another, more expensive thing to break. Every time I see someone make 280kw on 98 and 350kw on E85 on the same equipment I just cry a bit and really wish they would just stay on 98 in that exact scenario. It's bad for you.
