Hi All,
Im currently tossing up if I should put a POD filter into my stag. Currently Im running the stock box with a hi-flow blitz drop in panel filter, keeping in mind the scoop is slightly cut down to allow for the FMIC piping.
The main reason Id like a pod is purely for the added induction noise, I know its a bunch of wank but hay....
The only reason I havnt purchased a Pod yet is becuase a. I dont know what one to get (want one readily available) and b. I would like to (MUST) have some form of cold air feed to it.
So those of you with pods could you please post up your setups of what pod and explain ur cold air feed, pictures would be great aswell :D! I think i rember seeing in tangles engine bay and he had something going on around his? cant remember 100% thou.
Hows this for a pod setup!:
https://www.sau.com.au/forums/topic/248469-your-pod-setups/
the best pod imo is the apexi because in the kit form it bolts straight on to your intake and has a bracket to hard mount it to something ( which makes it legal in good ol wa ). shure there not a good flow as the 3a but they have the funel which is ment to swirl the air for better intake... whith the pick of the pod on that stag, i wouldnt want to be driving it on a wet day. its begging to suck in some water
http://cgi.ebay.com.au/APEXi-replacement-p...%3A1|240%3A1318
link to pod that will bolt straight on to your afm.. just got to make your own braket like
http://cgi.ebay.com.au/Nissan-R33-R34-GTSt...%3A1|240%3A1318
im sure you get everything in the first on except the braket which u can easily make yourself and save a heap
Edited by jippa
https://www.sau.com.au/forums/topic/248469-your-pod-setups/#findComment-4311059
I got rid of my pod and put a standard airbox and snorkel back with a highflow filter because I found the sucky noise tiresome. I am going to add a cold air supply to the top of the airbox.
If you really want a pod you will be sucking in hotter air unless you have a heat shield. Here is a link to the best i have seen so far:
http://www.skylinesaustralia.com/forums/Ma...at-t208224.html
https://www.sau.com.au/forums/topic/248469-your-pod-setups/#findComment-4316100
mines in the middle of production :D .. just need a lid cut out and attatched then sent for powder coating,
Robert , how's those highflow pannels work ? notice any differents in pull between pod and hi flow ?
I could say its heaps better since i put in the airbox with the Pipercross panel filter but then i would be no better than the guys who put on a pod filter and say their car goes miles faster. In truth i can't tell the difference. However SK has done the research (and written it up here somewhere) with temperature sensors in the filter area and one outside in the cold air stream and the difference can be very great.
I have no doubt that if you made up a heat shield such as the one shown in the link from my previous post and fitted a cold air supply you would have a perfectly satisfactory set up complete with sound effects ( a plus for some, a negative for others).
I am also sure that my set up with a highflow filter in the standard airbox will be just as effective but I am adding a cold air supply to the top of the airbox from behind the LH headlight and fitting an air diverter, and making a shroud to direct all the air from the LH scoop into my Trust SMIC ( which incidentally has been coping well on my track days when although the engine, tyres and brakes are all as hot as the intercooler pipes remain OK. In fact I had upped my turbo timer to 5 min on track days but I have cut it back to 2 min because i noticed that when I pulled up and felt the intercooler pipes they were OK but after 5 min idling they were really hot - absorbing the surrounding heat.
BTW my GCG turbo has got me another 35 KW from 155 AWKW @ 10psi (stock turbo) to 190 @ 14psi so i hope with a little more fiddling I will make my 200AWKW at 16psi.
https://www.sau.com.au/forums/topic/248469-your-pod-setups/#findComment-4317170
A little off topic but, I saw a red P plated (vic) the other day with a pod filter coming out the top of his bonnet.. And to top it off this was on a tf magna haha.
Back on topic, my brother and myself both use stock air boxes with high flow panel filters.
https://www.sau.com.au/forums/topic/248469-your-pod-setups/#findComment-4317715
  • 3 weeks later...
Ive got a cold air inductiion box from sau SA member Maxx.
was for an R34 and is sheet metal etc.
uses the stock standard snorkel and has the area below from the two original intercooler pipe holes..... Im using return air feed cooler so my holes are being used but when I go to a Greddy plenum and redo the fmic I will have a hole spare and can tube in more cold air induction.
so, z32 afm sits on outside of the metal box with lid and stock snorkel feed coming in, air from underneath if you have an upgraded fmic, pod filter sits securly inside and the lid closes it all off.
no engine hay heat to speak off, although the heatsoak is quite extreme so the inner side of my CAI setup is heat-foam insulated.
pics when I get the Stag back from headwork. .... still waiting.
https://www.sau.com.au/forums/topic/248469-your-pod-setups/#findComment-4348694
^^ relax m8 im in same boat, still duno what to do.
i looked at moding the standard box to make way for bigger snorkel (more noise n flow) but didnt work out so that ideas out the windy.
i think the pod and custom box is the only way to go 4 louder induction noise, i just dont want a big defect under my bonnet. i suppose if done neatly and slap a couple of emission stickers on it most cops would be none the wiser.
https://www.sau.com.au/forums/topic/248469-your-pod-setups/#findComment-4348889
Well Ive got good news and bad news.
The good news: since I'm on holiday i spent the best part of a day (some hours spent planning, drink in hand) neatly enlarging the intake to my SMIC cutting away the inside plastic on the front bar but so that it still looks much the same as the other one from a distance. Since I got a bigger Trust SMIC the old shroud was no good so I have now made up ducting whuch ensures that 99% of the air that comes through the bumper duct goes through the SMIC. Took it for a thrash and the outlet intercooler pipe was really cool to the touch. I am hopefull this will translate into more KW and better track performance and enable me to stick with the SMIC. Then I cut a hole in the end of the standard airbox lid because I am going to duct air from behind the LH headlamp into the box (to supplement the snorkel).
The bad news. The next day I picked up the airbox lid and noticed that because I did it on the bench, upside down, I had made a neat hole in the wrong end of the lid!!
Luckily i hadn't thrown away the piece I cut out so I have resealed and am now starting again on the other end!
https://www.sau.com.au/forums/topic/248469-your-pod-setups/#findComment-4349334
lol dont ya hate that man.
gave my brother in law my cardboard air box, for him to make out of galvanized steel. he did make the box only inside out.
since has been fixed up, but after finding a wet air filter after the car wash. that idea is down the toilet and going back with stock box k&n panel
https://www.sau.com.au/forums/topic/248469-your-pod-setups/#findComment-4349506
hey all well i took off my standard air box and put on a pod that i had on my ol' 31 sedan. This was so that my girlfriend could hear the blowoff sound lol
sorta got sick of it, plus everyone i know with a skyline is like " keep your stock airbox just put a high flow panel in"
so i did last week and i cant notice any difference in power, if anything it goes a bit better i would say :thumbsup:
however.......after looking at those cai kits from maxx...hrmmm makes me wonder
https://www.sau.com.au/forums/topic/248469-your-pod-setups/#findComment-4351823
Well i Currently have a stock air box with a blitz hi-flow panel.
Pulling on the throttle cable with bonnet up and hand on the scoop you can feel it sucking alot of air, so much that i think it would be borderline starving itself. So I've got a blitz pod on the way but I will be putting it in some sort of enclosure with a cold air feed.
In my opinion pod in enigne bay without some sort of surround and a cold air feed = epic fail/ hot air induction *heaps cool, thumbs down haha. end rant.
https://www.sau.com.au/forums/topic/248469-your-pod-setups/#findComment-4352236
Personally i don't drive with my hand over the air intake so no problem. Also if you stick your hand out the window at anything over about 60 k you will find a fairly good airstream which Nissan has designed a snorkel to divert to your airbox. Just the same I am getting a second feed of cold air from behind the LH headlight into the top of the airbox and an air deflector (if it ever arrives from Aus) will help as well.
[slightly off topic] Didn't finish my extra cold air supply today because I managed to get a cheap timing light and so installed my adjustable exhaust cam gear instead - easy job if you're not doing the cambelt as well. Set it at 4deg retarded and now just have to save up for a top class tune.
https://www.sau.com.au/forums/topic/248469-your-pod-setups/#findComment-4353868
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
