  • Replies 305
really?? hmmmmmmmm
na, i think the boss would kick my ass, if it was mine, i would.
i could always put wendys auto lancer on the rollers? no shit, i reckon that thing has about 13fwkw ! pos
Going to the next modern Reg' chad?
It's the day after the dyno day (15th)
Nope, I want to try and enter the time attack at the end of the month.
Hey Chad, yes if you request to be put on first thing that shouldn't be a problem, just note it on your entry form I think.
I'll have a chat to GW about it.
are you still trying to put the club members together against the Jz boys
Matty 31, should be plenty of spots left, call GW as they will be able to tell you.
Madaz, im not one of the organisers sorry, that would be best directed at Dan, BLU555.
The classes are still going ahead (RB vs JZ), but i don't think they will be back to back. so if DSTROY makes the most out of the RB's early morning well he'll still be the winner.
the days, although busy arn't heaps strict so if things can be juggled around to suit everyone as best as possible that's what happens :(
Edited by BlitzSSS
Chad,
If you need to get on early, I can organise that, no problems. As Paul said, there can be some suffling around of places too to accomodate entries.
Thanks for your supprt guys too. It's great that irrespective of the club, we can all get together and enjoy our cars. Oh yeah, expect some very heavy hitters from the GSR Evo club too!
Cheers
Daniel.
Chad,
Cheers
Daniel.
So is there anyway we can know before the day what times our runs are?
i know this starts at 8 and i will try to get there before then but just wondering if
there is someway of knowing when my run is thats all
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
