I bought a series 2 about a year ago and did my 1st 2 mods on it when i bought it which was a pod filter and split fire coil packs. Since then ive bought a power fc and a gfb manual boost controller. my standard dyno figure was 100awkw without pod and coil packs and 110awkw with pod and coil packs. how much power should i be expecting with the powerfc and boost controller? Remembering i dont have an aftermarket exhaust and intercooler. Also i have a bosch fuel pump, do u advise that i put this in b4 i get it dynoed or will the standard pump be ok as im not going to get maximum power out of it due to not having an exhaust and intercooler.
Depends, if your running a standard exhaust and no aftermarket front mount intercooler i reckon 130awkw.. With the very small mods you have your very restricted at the moment..
With a good tune you could get around 130 - 140AWKW at 10 psi. I doubt that you would see much difference from the new fuel pump but if you've already got one why wouldn't you install it now - might give you a little more security of fuel supply (safety rather than more power). You'll get a dramatic improvement from a new front pipe and three inch exhaust system (gut the cat or ditch it depending where you are)...at least another 30 AWKW
I take it you have a manual?
KiwiRS4T
would you advise 10psi on stock intercooler? (im not 100% sure its a great idea)
I say go the intercooler, zorst and fuel pump then get it all dyno'd in one hit. might save you some time and money on getting it redyno'd.
KiwiRS4T
Shouldn't be a problem. I'm running 16psi on my Trust SMIC and people have done 220AWKW on the GTT SMIC (bit bigger than the stock Stagea) but if a front mount is in the planning then yes doing them all at the same time makes a lot of sense.
The R34 smic is supposed to be good for 200kw. See DIY section.
And its less expensive. Also cut out the corrugated section on the inlet pipe and replace with 3" ss pipe.
Thanks
Sorry forgot to mention that it has a 3 inch front pipe and high flow cat, just standard cat back. Are the fuel pumps easy to get to?
Yeah its a manual wouldnt have an auto, couldnt have an auto!!!
KiwiRS4T
I would but i dont have the money to spend on them at the moment and im taking my stagea home to tassie and i would love just a little extra power than last time.
His car is a series 2, so it has the "r34SMIC". personally i would be fitting the pump, the stocky is what, 10years old?
I would personally get an exhaust sorted before the tune, so as to save money on retuning.
Ryan
Thanks
Yep you can get it without dropping the tank. Run the fuel as low as possible and then rip up the floor in the boot there is a panel in the top of the tank. You may have to stuff around with the bracket to get your new pump to fit.
my s2 is a manual neo and it is pitty much stock except for a BOV ,10 psi ,K&N pannel filter and my exhaust isnt the factory one
but it is just the same and im getting after a tune on a AWD dyno 170awkws . i dont know why you guys are talking such low figures like
100kw - 140kw because you should be getting that from the factoy with out any mods
nah not quite, here are my figures from my car over the past few years
series 1 auto awd
factory - 100kws tuned in rwd with driveshaft out
with pod filter and cat-back exhaust = 115rwkw
with safc = 130kw
with sitc = 140kw
with 040 fuel pump and turbo dump pipe = 160kw
with highflow turbo = 180kw
with ecu remap = 200kw
with poncams & headwork = 220kw ?
with extra fuel = 240kw *
(? for as in, being tuned now, and * as in next tune)
series 1 auto awd
with safc = 130kw
with sitc = 140kw
Hi Tangles
I have just got my GCG highflow fitted and I'm getting 190AWKW. I was hoping for 200 but will be putting in an adjustable exhaust cam gear and with a better tune should top the magic 200. What do you mean by "extra fuel"? Are you getting bigger injectors?
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
