The spec S non turbo exists in Japan however it can't be imported as it doesn't meet the power to wight ratio to make it an eligible import. The Autech non turbo version is eligible however.
There are around 25000 spec R's made that we can import up to 08/2000 but only around 200 Autech non turbo versions meaning that are are few and far between in Japan and at the current exchange rate not much cheaper than the turbo version so I doubt you will see any of these come into Australia for a while.
Jon @ Carizma
https://www.sau.com.au/forums/topic/248924-non-turbo-s15/#findComment-4317615
I've been in an Autech S15 and it's not bad. With a pod filter on, the induction note sounds like VTEC.
That said, I'm not sure if it's this specific example but it was down on power. I think it only managed around 100rwkW at a dyno night I went to. Everyone was reading low that night, but that's really low.
Without the turbocharger to make up the midrange torque, it definitely doesn't feel as fast as an SR20DET making the same peak power.
https://www.sau.com.au/forums/topic/248924-non-turbo-s15/#findComment-4317788
We get them in NZ. Cheap as balls. Why? Because they suck. Last one i saw sat on a lot for 9 months. Had full exhaust and a mean set of headers too.
I just dont think anyone buys an S15 for the hell of it. They want the turbo. haha
https://www.sau.com.au/forums/topic/248924-non-turbo-s15/#findComment-4318298
I wouldn't call 100rwkw for a NA 2.0 four cylinder "really low". Certainly nothing too flash, but compared to Aus spec S14 and S15 SR20det's which make around 120rwkw its not too bad.
https://www.sau.com.au/forums/topic/248924-non-turbo-s15/#findComment-4325610
I would call 100rwkW for a car claiming to have 147kW at the flywheel "really low", since it's the same quoted power that the 120rwkW SR20DET makes. Considering it's practically the same drivetrain, you can't even claim differences due to parasitic loss.
If it was a standard Nissan SR20DE then yeah, it's a pretty high number. But for an engine with uprated internals, cams, tuned-length exhaust manifold, etc, it's disappointing. B18Cs and K20As will make more power than that.
https://www.sau.com.au/forums/topic/248924-non-turbo-s15/#findComment-4327699
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
