  • Replies 99
internal, and he is probably looking at needing to run ~15-17psi
Correct - Its internal but I plan on running about 20psi from the turbo (17 - 18psi at the manifold).
I'm getting a new turbo aswell. HKS 2510 :):thumbsup::D;):banana:
2510? Thats a bit small for an RB20 isnt it?
That's what he is after, something small and responsive.
Fair enough but I think that a better option would be an HKS GT28/35 Pro S - Extremely responsive turbo but big enough for real power gains.
Im expecting the 30/76 to reach full boost (20psi) at around 4000 - 4500rpm, it should start building boost from around 2200 - 2500 though.
Im not 100% sure though, your best off asking someone who uses a GT30/76 already.
mine starts building at 2500-3000 i get full boost at 3500
so 20 psi at 4 sounds about right
Its not how small it is but how you use it
I should be getting full boost (20psi) around 2500-2800, boost coming on around 1500-1800, and hoping to get 200kw at the rears or more, but with a mega torque curve (for a rb20)
Should be able to use 3rd when I was needing 2nd before at wakie, and I wont bog down as much at motorkhana's/Drifting
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
