ok iv had my R32 GTR for 3 weeks now and bought a E11 V2 haltech,front pipe for it.
the mods for the car stand at
haltech ecu
s/s front pipe,3" all the way with one big resonator and a jap spec muffler at the back9system is not perfect by any margine and still runs the compliance cat
apexi suction kit(still runs the air flow metres(disconected)
cooper plugs
exedy h/d clutch
profect b boost controler running 14psi
the car also runs 20"x10" wide which i was told isnt to power friendly.
this is about it,the car made 293.4 HP
the machanic who is justin at CTP qld said the motor probably isnt standand as they dont make that power.
i cant thank justin enough for the work he did and will be using him again....thanks mate
https://www.sau.com.au/forums/topic/249254-dyno-and-tune-on-my-new-32-gtr/
Considering 60 degree intake temp (adding a nice correction, read - higher number) and 218rwkw.. its certainly not the highest result for 14psi we've seen, more towards the lower end if anything.
People have made 240-250rwkw on 1bar (14.5psi) easily enough time over.
As for the motor being modified - i highly doubt it. To make an assumption like that really isnt the best as there is no indication from a result thats a bit low
Im not saying its a bad result, however its nothing overtly better than anyone else.
You need to change the cat, and get a set of cam gear's on there... then see how it goes. Should be up closer to 240rwkw like everyone else with a nicer midrange
well this is a nice way to burst my bubble....
yeah its i big deal to me as this is my first GTR as i come from rotary and v8 side of the car scene.i use to own one of australias fastest drag rotor and didnt epect much from the dated datto.
iv got HKS step 2 cams and gears and full fuel system to go in as well as a to4z.but wanted to know what it would do before the mods.this is my day to day car so i didnt think id star with a hell of a lot.
scotty
Not really bursting the bubble - the dyno results thread would confirm what most are saying here.
T04Z on a stock motor?
I'll say a prayer for you tonight mate when i talk to my blown engines in RB heaven ;)
I made 230awk with PFC, pods, front pipe + 3" ex, very little cam gear adjustment. @ 0.9bar (13psi)
tuner tells me he had a run of 275awk when boost didnt hold and spiked at 1.4bar (20psi) which is where he lost the AFR's readings. As we are not sure on the ex turbines on my car I keep it at the tune he dialed in.
get ready to empty your wallet as it doesnt take long to get used to that kind of power and when I get a spike those extra kiler wasps give me a woody and now I'm chasing 400awkw.... but I think i'll do a rebuild first :P
cheers
Yeah you're gonna get used to that power real quick as the chassis is just begging for more. As far as cats go, you could look at a ceramic one from CES, got one on mine but it's 350 bucks- trevor does a nice job with the taper pipework which keeps the boundary layer from separating from the walls and keeps the gas going through all the core. Pulled my magic cat with the shallow tapers off my previous ride and the whole centre had detached from the sides and was knocking around. Of course if you're heading CES way you'll want to check out his race dumps and front pipe which from experience bring boost on about 500rpm earlier and give a nice little extra push on the back. But a little hard on the wallet....
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
    • Sorry, just assumed that talk of coloured pads meant EBC red/green/yellow/shit stuff. I don't know the DBA pads, but it's a reasonable bet that they will be OK. DBA make good stuff generally. Those 4000 series rotors I linked to are very good. I may well replace the RDA rotors I have with those when required.
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
