TiTAN Posted February 4, 2009 Share Posted February 4, 2009 hey ive tuned your car!!.. Twice! Stop your whinging!& No can do Titan.. you got stock turbo.. i am guessing it would break on your first anti lag. ignore that bit i want the wanky idle the antilag would have an arming threshold of 8000rpm and 100% throttle. but you have to have it on for the ilde so running 0 degrees ignition retard with an arming rpm that i wont reach will mean it never triggers and my exhaust wheel remains out of my cat. Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4407052 Share on other sites More sharing options...
Swiper the Fox Posted February 4, 2009 Share Posted February 4, 2009 I know you have, and it's still alive! It would be in skyline heaven if I tuned it Guilt-toy is a gun tuner...im going to get him to look at my 13th century medieval harp as well. Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4407056 Share on other sites More sharing options...
SECURITY Posted February 4, 2009 Share Posted February 4, 2009 im going to be installing my vipec tonight so i can get it in before my engine is started. ive got a few questions. i want to hook up my wideband to it, where do i get the expansion loom from? how much are they? i read in the vipec manual that you had to use a 1mm restrictor for the map sensor, has anyone done this? i was doing this with my greddy 3bar map sensor to keep the boost readings steady and it worked really well (except i had to use a 0.3mm restrictor). which wires does the IAT sensor connect to? Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4408820 Share on other sites More sharing options...
TiTAN Posted February 4, 2009 Share Posted February 4, 2009 IAT has to be wired in yourself to any of the AN Temp inputs (mine is on temp3 (expansion connector)), you can wire your wideband up through the NB oxy wires (AN Volt 6). My map line doesn't have any restrictors in it. Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4408842 Share on other sites More sharing options...
SECURITY Posted February 4, 2009 Share Posted February 4, 2009 is the expansion loom an extra item? Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4408885 Share on other sites More sharing options...
BoostedBarge Posted February 4, 2009 Share Posted February 4, 2009 The Vipec dealer can supply the expansion loom. Alternatively you can solder direct to the board (I did for my boost switch) Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4408886 Share on other sites More sharing options...
SECURITY Posted February 4, 2009 Share Posted February 4, 2009 The Vipec dealer can supply the expansion loom. Alternatively you can solder direct to the board (I did for my boost switch) i wouldnt solder onto the board, re-sale of it would be less if it was tampered with i think. is there a PC part out there that will work for now? Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4408909 Share on other sites More sharing options...
Swiper the Fox Posted February 4, 2009 Share Posted February 4, 2009 is the expansion loom an extra item? yeah..call Scott...he should have them in stock. Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4408908 Share on other sites More sharing options...
BoostedBarge Posted February 4, 2009 Share Posted February 4, 2009 I don't plan on selling it, so resale is not a problem...and it can be removed in no time at all I looked for a suitable connector at Jaycar, but couldn't find one. The pin spacing is very small. Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4408931 Share on other sites More sharing options...
Guilt-Toy Posted February 24, 2009 Author Share Posted February 24, 2009 Sounds great. I have an overboost problem at present and wouldnt mind checking out whether its teh boost controller thats causing the problems without buying an expensive new one. Solinoids are 100NZD (not sure about AUD) if you want a new one also.Look forward to hearing how it goes mate. Got the stock r33 RB25DET boost solinoid working with the Vi-Pec on the weekend. It works very good. Honestly if you spent a little extra time with the boost controller settings you could get it to have a very very flat boost curve. Mine spikes a little but i was happy with the way it spiked. You need to program the duty cycle per load point. So if it spikes you add duty number, if boost is too low you you remove the number. Took me AGES to work it out. but once i got it worked out I got decent boost pressure AND.... I did get 511rwhp with e85 but it was running very very lean up top because i was out of injectors. So yeah very happy with my flat power curve from 135 to 180 all the way it has 2hp more or less then 500 ! Just how i like it. Useable power revs. Changed back to pump The more I use my Vi-Pec the better i am getting with it, Twoogle was a breeze to tune as well. So yeah another win for this great ecu. Cost me 0$ for electronic boost controll and its only a 2 port solinoid!! Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4443516 Share on other sites More sharing options...
ahh 33 s2 Posted February 24, 2009 Share Posted February 24, 2009 GT, after all ur playing around.. how long do u think it will take a tunner to go from standard ecu to a full tune that includes all the cool stuff the vipec has to offer, such as setting up anti lag launch control flat shift cycle idle. and getting the boost control fiarly dialled in?? Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4443534 Share on other sites More sharing options...
Guilt-Toy Posted February 24, 2009 Author Share Posted February 24, 2009 GT, after all ur playing around.. how long do u think it will take a tunner to go from standard ecu to a full tune that includes all the cool stuff the vipec has to offer, such as setting up anti lag launch control flat shift cycle idle. and getting the boost control fiarly dialled in?? there is alot of setup there mate, like - Install ECU and run map sensor - Install air temp sensor in pipe and run wires - install digital input to clutch switch and run wires - Set timing on engine - Map ecu for cruise and boost... Thats a big mission.. I would think it could take 4 hours totally completed by a Vi-Pec experienced tuner. He would have to be good at what he does and know how to do it and has done it with this ecu a few times. I did notice with pauls car that when i was setting up and getting ready to tune I was flying through the setup and getting all configured and working ready to tune in no time at all. So yeah 4 to 5 hours if nothing else goes wrong - Drive in - Drive out deal. I would love to see someone setup a Power FC and tune it in that time, setup a aftermarket boost controller and setup a aftermarket launch interface and then your still missing anti lag and PROPER flat shift with time delay and timing retard. So yeah this ecu is friggin awesome now, once its actually fully finished and developed properly (Ray hall is continually working on improving it and adding features) it will be a pretty damn good first choice ecu for all applications. Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4443552 Share on other sites More sharing options...
Swiper the Fox Posted February 24, 2009 Share Posted February 24, 2009 i want to hear mine on cycle idle. Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4443565 Share on other sites More sharing options...
Guilt-Toy Posted February 24, 2009 Author Share Posted February 24, 2009 i want to hear mine on cycle idle. it wont sound as good as your car idles normally. smart ass Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4443577 Share on other sites More sharing options...
TiTAN Posted February 24, 2009 Share Posted February 24, 2009 give it a go anyway Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4443620 Share on other sites More sharing options...
DRD-00F Posted February 24, 2009 Share Posted February 24, 2009 lol, it'll fight the cams and sound normal Link to comment https://www.sau.com.au/forums/topic/249281-guilt-toy-installs-vipec-v44-plug-in-base-tuned/page/8/#findComment-4443637 Share on other sites More sharing options...
