Ok - it seem these are RE-11S (as opposed to just Re-11). Released 1/12/08 so maybe a bit early to tell how good they are but seem to be aimed at the autocross guys as they seem a bit softer than RE55's from the had to read charts! LOL
quite a few guys in japan tell me the a050s are the shit. but then again a few of them liked the a048s too which didn't enjoy much success here.
i only know one guy who's even used the RE-11S and he was pretty impressed. but yeah a bit early to tell yet. not enough folk using them. and often what seems to work OS doesn't always work in aus.
Duncan, Khumo whats? For track application? Be interested to hear.
hmm shame I'd have to talk to gordon leven about either of them in nsw.
we've finally moved off the yokos on the khumos. 40% cheaper and about 50% better lol.
tyre noise is generally right at the bottom of the list of concerns for a track tyre. generally you want grip, consistency, feel, tyre life, and cost. noise doesn't really rate. :cheers:
Also would love to know which khumo's as my re55 have reached the end of their life and would love a cheaper alternative...
Yeah we found the same thing. We found the little tyres that suited the EVO's / WRX's were cheap as but the bigger sizes needed for skylines were more expensive than the Bridgestones.
I went down and chatted to Bridgestone today as well about these new RE-11S tyres. They'd never heard of them (they had to google them!) and pretty much said not to expect any here for at least another 12 months.
not bloody surprising... by the time we get some they will be superseeded.... just like we still don't have a nissan R35 and they are already up to mk 2 and Spec V.... being in a small economy sure does suck.. :(
Don't know how much of a rush I'd be to getting them anyways. I got some priced from a supplier in Japan and at 43,000yen per tyre for 265/35/18's plus delivery you are looking at a pretty serious bill by the time they arrive here!
That makes DZ03's look reasonable in price. In fact the price of R comps over the next year or 2 could become quite scary I think.
  • 3 weeks later...
sorry I should have been clearer. Production Car (and Improved production for that matter) have a control tyre, for the last few years that has been Yoko A048R (and A032R before that). $500 per corner for 245/45/17 and the only place you can buy them in NSW is Gordon Leven (Gordon is kind enough to refund $5 from each tyre back to the street sedan race club).
From this year Kumho have won the tender and we are now running v70a/v700. They are about 30% cheaper and will perform better.
In particular the A048r would be about 1 sec quicker on laps 2-4 then they just go downhill, so if you can afford $2k in new tyres each time you go out you can set some good times on them.
  • 1 month later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
