CPU is clockable, but you might want to update the graphics card.
We had talked a little while ago about massive price drops on the current range of high end cards as dx11 is due prob early next year in which case if you can hold out you could a $600 card now for close to half price. Could be worth the wait.
Only paid $40 for the 8600GT, there's no real point in buying more PC parts because I've nearly finished building my xbox 360 (plus I can play Crysis on medium in a decent resolution lol). I was going to get a 9600GT, but for the amount of games I'm playing on the PC these days there wasn't much point.
I currently have the Engine set on the video card to 600mhz, the Shader to 1250, and the RAM to 850, running nice and stable so far.
When it's time for a DX11 card I'll probably just build a new box and get rid of my laptop.
DX11 will be only coming 'in' 4-6 months after DX11 comes out before you can actually make use of it.
So that will be 2010. Hence i just grabbed a 4890 for now... sit on that till Q1 or Q2 in 2010, then upgrade again by which stage the initial 'release' prices will have fallen nicely and 2nd Gen cards will be coming out too
ATi are apparently on track for DX 11 with Win 7. So once ATi and nVidia have DX11 cards I'll get some new ones, nothing to do with DX11 they just happen to be the next gen of cards.
FYI the 8600 is a dog turd of a graphics card as it's memory bus is tiny so no matter how high you OC it's hobbled.
Edited by DivHunter
Ye, true Jacob - although im just gonna wait, dont need anything greater than a 4890 at present
^ the Sapphire one is a waste of $$.
Buy a standard one and it'll clock to 901mhz.
I have the PCS+ 950mhz and better cooling, ok so far but wont clock any higher, so i need to investigate how much voltage its running in the next day or two
Talking about GFX cards....
If you have OC'd your graffix card and you are using RivaTuner DONT UPDATE TO THE LATEST NVIDIA DRIVER.
Long story short the new driver is not supported by Riva Tuner as yet and the latest riva tuner is still close to a month away
So all my clocking of my 9800GTX has now gone :-(
There are some work arounds but generally they only change the fan settings under load NOT the OC itself.
Quite annoying really.
Hey guys,
Just wondering if you could give me some ideas for a new media PC i want to get going. Got a fancy new TV so i want to be able to record tv easily using webscheduler etc as well as browse the net and network the TV.
I'd like to get out of it as cheaply as possible but also want a computer that can run HD TV nicely and a few apps at once. Main things I want is -
- minimum 1Tb HD
- GFX card with HDMI/VGA output
- Dual TV tuner, preferably with one analogue tuner but not essential
- Plan on running windows 7 as an OS, and want fast start up time etc
Obviously i need a psu, mobo, cooling etc to support that stuff but i'm not too sure what i will need. Also a nice small case would be good as it will sit near the TV. Would you guys have any suggestions as to whether i'd be best looking at some second hand gear, or just get all new, and if so, whats the best to go for these days?
Did you try and OC the PCI Express bus?
you're lucky :D
I'm not willing to bet a HDD of data or similar on possible corruption setting it about 100Mhz, some people will when benching and using DICE and so on...
Especially not once i stick my raid0 setup together lol
I've had not problems with pushing it between 100-110 on my X38 mobo running X48 Rampage BIOS.
I've used the P5E and the Rampage Formula and they both can run 110 pretty easily however other boards don't like it at all and can also kill your cards. Especially non-grpahics cards in the PCI-e slots.
To give you an idea
E5200 - $90
500GB HDD - $70
4GB DDR2 - $60
Thermaltake VK81221N2 - $150
Tuner Card - $45
DVD-RW - $25
Mobo - $115
Total $555
So if they are charging $600 that's a pretty good price for that. Although I'm not sure how it would go playing HD stuff to be honest, and that is where everything is heading so IMO you'd might as well build for it as its not that much more
To give you an idea
E5200 - $90
500GB HDD - $70
4GB DDR2 - $60
Tuner Card - $45
DVD-RW - $25
Mobo - $115
Total $555
Thanks for the price comparison - they are some very competitive prices.
Regarding the HD, thats one of the reasons I thought I'd ask here - from what i've read, most modern budget systems are more than capable of HD stuff and anything more is overkill... any more thoughts on that?
Dude, you should be fine with Full HD content on that system. My current media pc is an old Athlon 64 3500+ with 2gb DDR400 ram. With an old 7900gtx graphics card. I can play full hd content no worries(1080p if only program running, and 720p with a few programs running). Bare in mind my system has been slimmed down considerably, but with the advantages of a faster and more effecient setup like yours, you shouldn't have any problems at all.
Best of luck
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
