Hey again,
Over the past couple of weeks, while surfing the net, I’ve seen numerous amounts of people asking about yellow headlights and how to restore them to factory fresh. I’ve even seen as far as people setting up group buys for $150+.
Now this really annoys me, as it’s a very simple process to do. Then you get people saying it’s really bad when they turn on their lights, so quickly come to the assumption it’s inside of the headlight. I guarantee 99% of the time it’s just on the outer surface.
This guide offers you guys a simple, cheap (talking about less than $10 here) yet equally effective solution. I’m talking no buffers, no special chemicals, no tricks.
Now, for those who don’t know, here’s a low down on why headlights turn yellow. It’s plastic! Simple. Like any plastic, as it ages the clarity disappears.
This really only happens on R33 and R34 Skyline’s due to the plastic housing headlight, unlike the R32 which is made of glass. Hence, this tut applies to all R33 and R34 Skylines.
Right:
Tools needed:
-Wet Sandpaper / Automotive sandpaper. You can pick this up at your local hardware store or auto paint supplier. You’ll need 1000, 1200, 1500 and 2000 grit. Just one of each will be more than sufficient.
-Car wax. (Just any reputable brand should do, or any you have lying around your house)
-Masking tape
-2x Pieces of cloth, preferably something not rough.
-Strong buffing arm
Step 1: Sandpaper / Preparation
Start by ripping considerable pieces of same paper (of each grit) and let them soak in a bucket of water for a good 20 minutes.
Whilst the sandpaper is softening now’s a good time to mask of the car. Now this is a very important part as you want to mask off nay part you don’t wish to sand. You can never be too careful or use too much masking tape.
HINT: Instead of masking your bonnet, have it open all the time, that way you can save time and don’t F*ck it up.
Step 2: Initial sanding
Start with the highest grit 1000 and start sanding the headlight. You should sand the headlight for a good 3-4 minutes on each grit. Now do you see the yellow particles you’re sanding off, yep that’s a good sign not just an illusion.
NOTE: When sanding you should only be sanding in one direction, i.e. left – right or up – down. This prevent swirls and deeper scratches.
Also while sanding always keep the sandpaper constantly wet to prevent clogging.
When finished, give it a wipe with some tissues. It should look like this a very dull finish.
Now your probably thinking at this stage “What the F have I done, it’s ruined. I’m going to kill that Chang guy” No no, don’t worry it’s all part of the process. Just keep reading.
Step 3: More sanding
Now after using 1000 grit slowly progress down, 1200, 1500, 2000 till it looks like (After final 2000 grit)
Step 4: Polishing
Now I’m sure like me, majority of you don’t have any special chemicals or buffers. Too expensive, too difficult, too lazy, too can’t be f’d
Anyway, get your polish that you’ve got and polish it like you would a car. But really get into in. I mean rub it hard. Use a lot of elbow grease.
Till it looks like this
NOTE: You should be polishing in a circular motion, as opposed to the sanding technique.
Use the second cloth to wipe away the wax as per normal. You should be waxing until you can’t feel your hand or about to pass out.
  • 1 month later...
  • Replies 44
For light yellowing, you can get away with a product that Just Jap sells. It is a japanese polish specifically for headlights, with japanese writing all over it. You can also use a generic headlight/plastic polish from companies like 'Mothers', it will do the job, but is slower and requires a lot more patience than the Just Jap tube. In the old days we used to use toothpaste and then car polish. The old 750cc Suzuki two strokes [waterbottles] had a plastic lens on the speedo and tacho, the toothpaste/polish thing worked fine [probably prevented decay and gave a fresh mint finish as well.......lol].
autosol ftw!
I use Autosol to polish acrylic, so I'd expect it to do a good job on headlights too. May even be less elbow grease than car polish. Also, Maguires do a plastic polish/restorer which may work easier. Great tut! Must have saved peeps lots of $$.
ive done mine twice with meguiars scratchx
first time didnt last that long but the second time i did a couple weeks ago and they still lookin good. pretty cheap, not much effort (push hard and scrob until u hear it squeeking( squeeky clean lol)) then wipe with a clean rag and ur done.
Hey guys, thanks all for the comments.
This thread was posted accidently twice. So anyone want to post anymore info please keep post in the original thread :) There's more pictures in the original post as well
http://www.skylinesaustralia.com/forums/Ye...-R-t249906.html
Oh and a slight edit. I noticed I posted "CAR WAX" lol. You should only be using polish. As polish removes scratches, not wax. So anywhere it says wax I mean polish.
Edited by Chang
beware some/lots car polish isnt good for plastics, some oil or silicone based can turn them yellow faster ?????
if you want it done right, use aircraft windscreen polish found at just about any airport. the headlights are not normal plexiglass plastic but high impact lexan like plane windows
I used Megs M105 on my R34/Supra to get out scratches and haze then Megs plastic polish to tidy up the shine a bit.no sandpaper needed
perfect like new and they stay that way now for over a years while stored outdoors in salt(a few houses from beach), Adelaide sun
for the cost of new headlights, I wouldnt use shonky products or cheap sandpaper either.
Dunno if this has been said, but another great alternative is 'GlassyLite'. This product would restore your head lamps back to its factory condition. With the added bonus of UV coat, to prevent your head lamps from yellowing any time soon. I have given this product a go and it was just excellent !
I would highly recommend giving this a shot ;)
Here's the DIY link:
Edited by C.T_07
hmm so i went thru a drive thru car wash last night, now the top & bottom sections of inside of the headlights are fogged up.
anyway to get rid of the fogging ?
inside i take it? pull a bulb out and use a hairdryer or heat gun on no or low heat to dry inside.
if the seal is broken that will happen again when washed or rains?
yeh its in the inside as ive stated.
its strange cause it never happened before when i washed it myself by hand & bucket.
maybe the carwash sprayed at an angle wear the seal is broken on bottom of headlight perhaps.
i said it before and ill say it again, nissan failed BIG TIME with plastic headlights for R34
Hello,
You dont need wet dry paper
you dont need tape
you dont need nothing but 10 mins of your time
you need 1 rag and some fine polish ( 3M Finesse )
if you dont have a rag you can use ya old jocks
if you dont have polish go buy some this polish can be used on your car from paint to rims
start polishing within no time Ching Ching shinny new headlights
cheers
in the group buy that was offered a while ago (and sadly got shut down) if u want to go all out to stop it from happening, they were going to clear coat the headlights. so if u can be bothered, clean the lights as much as possible and u could take them down to spray painters and ask for a quick clear coat. not sure if it effects the light coming out by displacing it or anything like that but worth a try.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
