i did a search and went back to about mid 07 and thought no point going further back due to development. or i typed the wrong shit in.
any ways i have an rb25det s1 pulled down and it will be rebuilt with pistons and rods, bearings, studs, gaskets of major brands. the motor will see drift work plus track/grip. is there anything i should spend my money on to avoid say oil problems or somthing simialr which is easy to fix but can cause big problems if i dont.
any help you can give would be great.
cheers, steve.
https://www.sau.com.au/forums/topic/249968-comman-problems-with-rb25det/
there is a massive thread based on the oiling problems that plague the RB25.
I'd find it and do everything that it suggests, because most of the problems arise when doing track work, in high revs.
Dry sump will fix everything :P
But upgrade the oil pump
Good catch can and breather setup
Maybe head to sump oil drain
500mls extra oil.
dude, putting a bigger oil pump on, and not doing the rear head drain, or blocking the rear oil feed in the head makes the problem worse.
The whole problem is oil pooling in the head do to bad drainage at high RPM. If you put a bigger oil pump on, it will simply pump more up there and into the catch can, creating a disaster. I've seen this happen - GTR oil pump on a RB25 with no extra drains... or the rear feed blocked. Blew most of the oil into the catch can.. and then when the sump was starved... bang.
You're giving bad advice I'm afraid...
Edited by The Mafia
The advice I've been given by most engine builders is not to restrict the oil getting up top. It's all in freeing up getting it back down to the sump.
IE, you REALLY want a good drain setup to get it out of the head. Then, you're all sweet.
The issue is only at high RPM, so who knows what it's doing when you're blocking an oil feed off and sticking to low RPMs. You might be starving the head of oil slightly.
I did see a drain set-up for RB30 heads on ebay, was simply a fitting tapped into the rear of the head for extra drainage. Would thios also work on an RB25?
I'm just using the fitting that TUF_RX3 from here made, which is press fitting into the back of the head.
Others drill and tap a fitting in.
Well, the GTR have a blocked feed from the factory, and a restricted feed up the front. So less again.
I'm pretty sure SK has said that even with a blocked feed at the back, there is still more than enough oil for the hydraulic lifters in the RB25.
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
