  • Replies 2.5k
Posted Images
I am sure if Fisi had of been able to test the Ferrari before switching that it may have been a far tougher decision
An opportunity to drive for Ferrari for an Italian and debut for them in Italy..... Fk man I'd literally give up a nut for that :3some:
Kimi has been doing very well lately.
All R&D is for next season and he is still driving the nuts of that thing !
as for MW....no comment
trulli you bad a$$ loll
as for fisi, mate go bury your head into a pizza or something what the hell was going through his mind leaving the pits.....
Seemed like he was riding a pony instead of a prancing horse !!!!
...what was going through his mind leaving the pits.....
That was great. Heiki almost made up for his average performances in McLarens so far with that one move... almost
What's even more hilarious is when he overtakes a Toyota driver on the last corner of the last race to become the WDC, and makes little Brazillian girls go all teary.
Now THAT'S funny :)
I've always wondered how many $millions that cost McLaren last year.... Anyone know?
like some kind of western suburbs crack addict, im having to check planetf1.com a couple times a day, every day, to see if kimi is joining hammo next year
yeah, I was playing that game at work last week. lol
nothing. Toyota's own telemetry shows Glock was going as hard as he could on his dries, and Hamilton just had better pace on inters.
Either way Lewis is a choker lol, chokes on the last lap, chokes in the last 2 races of the season...ROFL
Had Renault not cheated massa would be champ. You all know that...
/end trash talk
btw kimi I think should be at brawn, because jenson sux hard... That makes 2 English chokers...
Okay, let's play that game:
If we go with the 'what if Renault hadn't cheated?' scenario, if Massa had have received a drive-through penalty for driving off down pit lane with the fuel hose (like He should have); then adding the drive through time to the time lost by the pit crew retrieving the busted fuel hose from the car, there is no way He would have finished in the points anyway.
What's more (and worse for Ferrari fans), is that Hamilton started P2. First and second placed Alonso and Rosberg quite clearly benefited from Junior's shifty self-pwnage (they started 15th and 8th respectively). So if Lewis had have finished in P2, He would have collected 2 extra points (or possibly 4) for that race.
So loser-boy finishes the season at Interlagos 3 points (or possibly 5) behind Hamilton, rather than 1
But it still would have been at least 1 point any way you care to slice it :)
Now can all the bleeding-heart Massa fan-bois finally s.t.f.u about this? Probably not I'd suppose, but it'd just be ignorant of the facts to keep crapping on about it...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
