none and buckley's?
too bad Toyota's usual modus operandii of 'rock up, dump a shit-load of money on the problem, win' didn't come to fruition. 7 years, not once on the top podium spot. ouch
F1's a very different beast to other motorsport discilpines
might have been different if they threw more money at a real good experienced driver? They've had the raw pace on a few occassions over the years.
  • Replies 2.5k
Posted Images
Reaing EVO a few issues back they wre talking about the new McLaren road car and his focus on making that part of the business work.
Does anybody remember the number of cars that must be on the grid otherwise promoters can murder Bernie? Forgetting the new teams for a minute.
Sauber and Toyota gone, and possibly Renault. ( i expect them to pull out, i dont care that they signed Kubica). So thats only 14 cars on the grid. I am half expecting one of the new teams to pull out, or at least fall over mid season when their hack has been or rookie driver bins too many cars and they cant keep pace with actual chassis etc etc
So is it 16 cars that must be on the grid as promised to even promoters? I think Bernie is going to have to get busy with some support for some people
Spot on. He's running the sports car and automotive technology section of the business now.
The day to day running of the race team is Whitmarsh's gig.
24 car at the moment Roy, minimum in most of the contracts is 14 cars, so 5 more teams can drop out before Bernie has any issues that way, and all he'll do at that stage is enforce the rule regarding to top teams needing to field 3 cars.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
