can it be true that webber future for 2010 is more certain that buttons or kimi's. how did this happen!?! go webber. WDC for 2010. yeah baby.....
ps, there must be toxic fumes in here.
  • Replies 2.5k
Posted Images
Arsuming can he beat his team mate. I for one will be incredibly surprised if RBR aren't a serious contender next year simply because we all know what Newey is capable of. Having said that though, I'd also be surprised if Ferrari have 2 mediocre seasons consecutively.
lets not mention '84 to '98 then, where McLaren and Williams took turns making Scuderia Ferrari their bitch for 14 seasons (+ Benetton sneaking one by in '95 with you-know-who at the wheel)
Hahaha I know, I was watching F1 in those days too... Benetton snuck one in there in 94 too. :D
McLaren have always been the most dominant of F1 teams haven't they? Even when stealing technical data from Ferrari and pretty much getting away with it! And some say Ferrari is protected by the FIA or is the FIA... what a fkn joke!!! :bunny:
Funny how the bitch still has more WCC, WDC and more GP wins than McLaren. Williams also have more WCC than Mc too :)
Yeh, reports here in the UK are that he ha agree to the terms and will sign by end of the week...with McLaren. I am not the worlds biggest Hamo fan, but after a year of srapping in 2008, binning it whilst on a podium position with a few corners to go etc etc....well in his 4th season Hamo is going to be stronger again....and Button needs to think carefully about how categorically SMASHED he is going to get beaten next year in a McLaren
In his rookie year the hack Hamo went wheel to wheel with Alonso and circumstances played a part in them only being seperated by one point. Button is still high on his 2009 WDC where he is confusing luck and opportunity with world beating speed.
I so hope this is true as i want to laugh at the 2009 WDC showing how ordinary he is compared to the last 4 WDCs!
could not agree more. button has showed yet again that he cares a lot more about cash than he does about loyalty or about winning. he's used his luck with BGP to get the big pesos for a few years at maclaren which will go well until they realise he is no better or worse than any of the top dozen drivers in F1. maybe he'll look good on their Tag watch ads which should in part make up for any deficiency in the car.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
