Hey,
Power FC is locked since its last tune by the previous owner. How do I unlock it? Do I need the special software or can it be done via the hand controller?
There's no power fc tuner here in rocky and I wanna upgrade the afm's.....
Cheers,
Chris.
https://www.sau.com.au/forums/topic/250173-power-fc/
it will need a re-tune.. can anyone confirm this but everytime ive unlocked a Croydon locked ECU it resets it back to factory defaults so you cannot see the tune... does that sound right?
yeah
mine came locked. had to reset and retune
https://www.sau.com.au/forums/topic/250173-power-fc/#findComment-4336178
Thats very interesting to know .
Is it only the fc's that croydon have tuned or does this happening when with every fc that has been locked?
How is croydon able to lock it and then when the fc is accessed by another datalogit or axcel software it get's reset to initated setting?
https://www.sau.com.au/forums/topic/250173-power-fc/#findComment-4336283
Not with mine and FC-datalogit; mine was last tuned by them about 3 years ago and I unlocked it after a hardware change about 2 years ago.
Maybe they're doing something different now...
Regards,
Saliya
https://www.sau.com.au/forums/topic/250173-power-fc/#findComment-4336428
this is a bug within FC-Edit itself, its not able to "see" the values so it overwrites them with its default when you hit update
this is common and very obvious with the injector settings, they get scrambled when you unlock it
i think its also different for different verison of the FC-Edit and PFC models, ie RB25 mangles the injector settings
and say RB26 may mangle other stuff, its just interface / validation bugs in their code (datalogits)
you would be able to unlock / relock a PFC with no dataloss with the correct sequence and code (ie: apexi FC Pro)
https://www.sau.com.au/forums/topic/250173-power-fc/#findComment-4336474
croydon is able to lock it as they have the datalolgit software, which you can lock a PFC tune
it gets "reset" when you unlock it due to an interface bug, its not croydons fault you have to reset it, once unlocked
croydon lock PFC tunes i guess to "protect" the user from doing something stupid on the hand controller
i guess that defeats the point of a stand alone engine management system, to allow you to manage it
https://www.sau.com.au/forums/topic/250173-power-fc/#findComment-4336478
nah it doesnt, should just be able to save the tune, then uncheck the "protect" ticks in settings 2 screen. i have a few customers come in with locked PFC's.... i also lock them on customer request as many have 'fast and furious" fingers and dont trust themselves... :D
Edited by URAS
https://www.sau.com.au/forums/topic/250173-power-fc/#findComment-4339195
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
