Hi guys, i have xenons but at night when i turn the lights on theres a dirty yellowish glow on the plastic. Looks really bad.
I just tried today using fine sandpaper on the headlights to scratch it off and used ScratchX to buff it up but it still didnt get rid of the yellow glow. The lights are not foggy in any way, just get this ugly yellow color which i believe is the oxidisation and heat build up on the plastic. Im thinking maybe the yellow layer is on the inside but not sure. Anyone else had this and what did you do to fix it?
https://www.sau.com.au/forums/topic/250251-dirty-yellow-headlights/
Yeah thanks mate - i dont suffer from the cloudy issue. The lights are clear as in the day. Just when i flick the lights on at night, im getting the yellowish glow to them - it's annoying me. I checked a few other threads before posting but no ones really mentioned if it was on the inside or outside of the plastic. i sanded mine down today and it didnt make much difference...
Guess i'll scrub them again tomorrow and finish off with some PlastX if i can get some...thanks anyway
Try this rather than spending $140 + $35 to get it back:
http://www.skylinesdownunder.com/forums/sh...ad.php?p=479143
It only takes say 2 hours, I'd rather spend 2 hours with a little elbow grease, than pay $175 :thumbsup:
Just have been observing... My headlights have a problem too, but not sure if it's the one as discussed here. My headlights look as if there are stains on it (like from water evaporating or something). Is it the same problem as the headlights losing clarity discussed in forums above and by people above?
yeh guys,
get the meguirs PLASTX
if you guys were @ the BBQ, remember (VQ35DRIVER i think it was) his headlights, they were yellow as anything!
i took some plastx and a terry cloth and cleaned a section and they came out clear.
just need some elbow grease and some plastx
Edited by BLISTC
Yep same issue, the water evaporating problem is the japanese acid rain, it also eats into glass on windows of jap cars too, it's a pain in the arse
mmmm....maybe that explains why on all the nippon cars I've owned, the window sill rubbers are always splotulated, or have some shit growth on them....anyone know what I mean?
Yep, I got some shit on the rubbers too.
Anyway, I have just gone to Autobarn, and they do sell the Headlamp restoration kit for $24.95 and Meguire PlasticX cost $18.95. The guy from the barn say the more expensive one works better and last longer. Check it out.
thanks for the input guys - ive just got back from the whitsundays so have been unable to reply. Skybarge, that's the method i did before posting. It didnt work but i havent used PlastX yet, i was unable to find it at supercheap and was told ScratchX was suitable as well so i used that instead. I'll hunt around AutoBarn tomorrow for the PlastX and apply some elbow grease to it and let you's know the results. *fingers crossed*
make sure u get some megures applicator pads or a pack of terry cloths also [should be two cloths in 1 pack]
you work it in a circular motion let the polish do the work. do a section at a time.
i applied a small amount directly onto the headlight and worked the area. then i got the other pad and wiped it clean off any residue.
i also used some of that blue tape to mask off all the surrounding edges like the paint etc. before hand because i didnt know how it would react to the paint in case i accidentally got some on there.
you will actually see all the yellow crap come off on the terry cloth! also when you run your finger over the headlight when its done it feels so smooooth
-mark
So like i thought, the PlastX didnt do squat....looks like i will need to remove both headlights, bake it in the oven, and remove the plastic to clean the inside....great fun. Not looking forward to this.
I've used plastic X its crap it didnt do much
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
