ok so havent driven my gtst for like a year now.. as i bought a GTR and now have an audi...
anyways theres a few things wrong with it.. i jsut serviced it today.. yet to do sparkies...i will tomorrow
but when i drive and come to a set of lights and go down through the gears.. and when im slowly rooling ill put it in neutral. the idles drop tooooo low and it almost stalls sometimes it does..(i think its the timing.. i remember taking the whole thing of whne i was "learning" about cars)
also when i drive
smoothly driving along... the all of a sudden it just cuts out... like the cars still on.. but its as if im puting the clutch it.. the revs just DROP and no matter if im pusshing the accelerator.. it still drops.. but then it kicks in for a second again... and then drops an kinda sputters
then it wont let it build boost....after this... it jsut goes back to normal
heres just a video of it idling...
can someone tell me what that HIGH PITCHED RINGING is???
Edited by bLaQ.bOi
Yeah id also back the AFM theory. Those symptoms sound like the sedate version of what happened with mine. Mine felt like i was out of petrol, youd put ur foot down & it would go, then stop, then go again several times a second. f**kin nuts!!!
As for the dropping revs, mine does that a little at times. I usually drive around it without even noticing, but i think the IAC valve on the back of the intake plenum may just need adjusting. Or it could even be the TPS not picking up 100%, either way i dont think its too major. Theyre the 2 devices that seem to play with revs when the car isnt yet at idle.
The not building boost issue, the only thing i could relate it to is either the ECU or turbo. If the turbo is blown, there will be a shit load of smoke i would think, but it doesnt sound like it. If you have the standard ECU, unless you are driving along in gear the engine wont build boost above 0. Its a built in safety i believe, could have something to do with whatever the sensor is for this. If the car is idling, or the clutch is in & you rev it, it just wont build boost, id see how the AFM bit goes, & if the problem still exists look into this.
PS, please let me know about the dropping revs if you solve it, should cut down the amount of time i spend stuffing around with it.
Cheers
ok thanks for the advice guys... sorry about the vid
here it is!
http://au.youtube.com/watch?v=GnLM99eCTVo&...re=channel_page
il let you know how it pans out
also theres a cable that comes from under my car thats attached to the cat... but its broken and not intact maybe this has something to do with it?
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
